can u use tomos a35 parts on the a55
i want to use the a35 speed kit on my a55
Re: can u use tomos a35 parts on the a55
John Joedicke /
Sure but you will need an offset for the carb/reed cage. Need to match transfers, and use a A35 exhaust performance pipe.
pretty sure that the bolts that go through the top end are smaller on the a55
John Joedicke /
True, but not a problem if you are carefull on your torque.
