need two of em (one for each of my bikes). this is the flex block that fits in the tension springs, behind the motor. anyone?
if you gut out the old rubber but keep the metal ring, you can do it a la Peter's method... grab some of those generic swaybar bushings and pop the metal ring an one of them into a vice. as you tighten it, it will bite into the rubber and cut it out... like a cookie cutter. perfect fit!
as we know these bushings are a bit stiff for the main engine mount bushings, but i think its fine for the lower mount.
otherwise ebay.fr has sets for sale sometimes that include the lower mount.
77 may have them. give us a call, not on website.
I got a few more of those urethane bushings if you want to grab them.
But they are less than $15 bucks for a set of them though.
I got mine from mopedjunkyard.com
