IN DIRE NEED OF PUCH RIGID PEDAL CRANKS
the frame is for an e50 but i have a za50 on there and tried both za and e50 pedal cranks and nothing fits inside, both are too big. don't know what size i need, so if you have some pedal crank from a rigid shoot me an e-mail @ skelechairs@gmail.com w/ your price. if you're from sf, i'm local, ya.
if this doesn't work out, i'll just be super racer and throw on some pegs yay.
Re: IN DIRE NEED OF PUCH RIGID PEDAL CRANKS
batavus pedal cranks are smaller they might work im looking at both of them.
measure the diameter and i can tell you
either your bushings are dead. or they are brand spankin new.
also i have seen two different sizes of bushings...... keep tryin.
i had just measured the diameter of the bushing and it's more or less 1.5cm and where the crank goes in is about 1.25cm more or less.
help me finish this bad boy.
still awaiting simonini to get welded, pedal cranks, and a chain (BREAKERRRRRR)
Pablo Puchasso /
Sweet. Is that a bennsaar (SP?) pipe you got there?
jus make it a noped
yeah that's that bennasar pipe, it sounds like it has some balls.
bump.
5 year bump!!!!
you ever get this figured out? 3
just sand the bushing dummy!
4.5 years later maize?
Never know. Maybe dude didn't realize he could use a little sanding drum on a dremel to sand out the bushings
