'79 50V with low miles... 360.... on the odometer. I cleaned the carb and changed the slide with an extra that was in one of the side panels, runs really good. It needs a pin on one of the pedals and also may need a new throttle cable assembly. It cleaned up nice and everything works as it should, however; there is some light surface rust from storage so it's not a perfect 10 by any means.
