need pedal chain for maxi
▣ß@ηℊℙℐṔ∃▣ ™ /
not sure if thats what its called but it has a regular bike chain on it that is way to small the tensioner is almost rubbing or if anyone knows what size whatever it all helps thanks
Re: need pedal chain for maxi
1/8th
bmx chain
▣ß@ηℊℙℐṔ∃▣ ™ /
cool thanks certain length?
You will have to make it the right length but its not difficult. I used a hammer and punch to remove the pin. Moped pedal chains don't have to be perfect tension because most have a tensioner, so as long as it is about the right length it is fine.
