Does anyone have an extra throttle cable?
If anyone has a throttle cable, i need one. Mines all screwed up.
Tell me how much.
Thanks!
Re: Does anyone have an extra throttle cable?
For a Puch maxi by the way
got mine at the local bicycle shop for like 3-4 bucks, its a 3-speed cable. BTW, I use a Dellorto SHA, dont know if its the same on your bike or not.
I have a bing on there
doesn't matter what carb you have. they all accept the same throttle cable. Take your old one into a bike shop and have them make you a cable to length. Its just a brake cable. Just make sure the end that has the little ball on it is the same.
good luck.
Just replaced the throttle cable on my Maxi with a bicycle cable, you just need a way to grind down the ball on the end to the correct size for your carb. Or I guess you can put a little ball of solder on the end.
Feed it up through and cut it to the right length once it's in.
