Crazy Josh's Used Parts BlowOUT ! BE THERE!
Howdy.
I'm moving to Seattle in about a month, and I don't really want to lug a bunch of stuff I'm not using with me. Thusly, I'm selling these parts, primarily Puch, AT X-TREME CRAZY PRICES. No reasonable offer refused. Nearly all of these parts are used, and all of them work. If it was broken, I'd just toss it. Additionally, I have a number of ZA-50 internal transmission bits not listed. If you need something, let me know.
Lot 1:
Puch speedo with housing and bracket 30mph $6
Pedal chain tensioner $3
Magura brake levers (Brand New) $5
Magura Throttle/Brake assembly w' grip and brake cable $7
Tomos A35 Engine cases, ported for 70cc kit $20
Tomos Targa A3 side panel $3
Lot 2:
Fuel Taps: 1 Orig. Puch, 1 new Paoli for Puch $2 each
Ignition Coils $5 each <-- i actually never used these, so ...
Side Rails $5 each or $8 for both: Crazy Low Prices!
90 degree hi-temp rubber flange for large carburetor (21mm) $3
E50 Drive gear w' clips, washers $3
Clutch Bell w' cover, clips, etc.. $8
Points, Bosch $2
R. Brake Assembly w' pads $6
E50 Ignition Coil Bracket $2
E50 Clutch cover $6
Tomos A35 12V 80W flywheel $12
Puch Rear Shaft, nuts, spacer $1 !! X-Treme!
Puch Rear Suspension Bolt $1
Lot 3:
Pedal shaft for Maxi and MKII ZA50 $5 each
Wiring junctions $Fuckin' Free Man
Centerstands $3 each
taillight gasket $1
Tomos A35 2000-2007 12v80w Stator/magneto & flywheel Retail: $140, Josh: $70
Random orphan pedal w' arm: $3
Puch flywheels 6V 4 available w' nuts clean tapers $5 each
Lot 4:
Maxi Rack $1
Bench Seat bracket $1
Horn $5
Puch E50 engine cases WELDED DECK face for lots of porting. Alas, shitty alum. weld on back of cases. Functional, but not pretty. $20
Nice rear shock 31cm $6
Rough rear shocks $3 each
Flywheel cover $3
Airfilter $2
Buyer pays shipping. $1 items will have $1 added (for the box) unless you buy something else. Want everything? Email me.
Thanks for looking!! X-Treme!
Re: Crazy Josh's Used Parts BlowOUT ! BE THERE!
dibs on pedal shaft and kickstands. emailing now.
maxi pedal shaft i mean
Email sent!
Dibs on the fuel taps, sending an email right now, thanks!!
OH! Forgot to mention that I'm getting the side railes, clutch bell assembly, drive gear, and the maxi rack.
did he buy both centerstands? if not, id like one.
jon...haven't paid yet...so you take one of them. i'll email him the update.
Jake Shaughnessy /
i havint posted it but i also emailed him a wile ago about one
emailed...does this guy still have stuff?
oh, well Jake, you get first dibs then. thanks though, jackson.
DIBBBBBBBS!!!!!!!!!!!!!!!!!!!!!!!!!!!!
magura throttle assembly
magura brake levers
1 ignition coil
e50 drive gear
clutch bell w cover/clips
points
for suuuure e50 clutch cover
random orphan pedal with arm
bench seat bracket
flywheel cover
emailed too!
Hey Everybody! Still catching up on emails. I will calculate shipping and get back to you. Paypal prefered, but money orders acceptable too.
Thanks!
hey josh, you wouldn't happen to have a clutch drum off of a ZA50 engine? and if you do have one, I've found that there were a couple different clutch drums, like mine that has 13 teeth on the clucth drum gear gear and others that have more gear teeth and a bigger inner bore. so i need a puch Za50 clutch drum with 13 teeth. if you have it, let me know.
thanks
damnit josh, you should have just brought it all to Seattle! We would have scavenged all those parts in a split second and put them to good use!
like i would have taken any and all clutch parts and that main gear and the pedal shafts...
why is all this stuff spray painted black?
wtf?? i would of bought half that shit
Seattle needs to simmer down! I've got boxes of crap that I'm bringing to freely distribute, and Brendan you get first pick through.
Yeah, I think I will be making a donation to the fleet of whatever doesn't sell, plus other bits not-listed.
Josh is very dark...
