prefer local buyer. square mount. you may need to buy a nut or two. less than 20 miles use. $150 bucks. call me 415 378 7821
getting rid of it already?
no ground clearance. at all. im too heavy
bumpola?
damn, I just bought one from QK on the 4th, def would have gotten this from you.
you can swing that pipe out to the side quite a bit Josh to get enough ground clearance. you'll just have to make a mini pedal crank for that side.
HMMM well i did take the pedal chain off first thing when i bought it. the problem is that i got gazelles and i got the 2.5's in hopes of avoiding muni tracks again. the space for the mount to go is extremely limited though... ill try it again but if i cant get it to work out its for sale for sure.
dude. i will totally buy it off you.
btw, cityhunter is awesome!
i never met a soul that didnt like city hunter
taller shocks.
or just stiffer ones !
yeah there has to be a way for that to work. taller/stiffer shocks is a good idea. motorcycle shocks even.
He already has tomos forks, longer rear shocks won't move his pipe any higher off the ground.
