FS Dellorto Replica 14/14 w/ Jets
$20 shipped
Clean used Dellorto 14/14 Replica + Jet pack for carburetor: .80, .85, .90, and .95mm jets.
Adjust your carb jetting to perform well with your other modifications!
http://www.davesmotors.com/store/product536.html
http://www.davesmotors.com/store/product556.html
Re: FS Dellorto Replica 14/14 w/ Jets
how used? always been curious about this replicas...did it perform well?
The jet range is limited to what I've got as far as I know, which is on the large size for 50cc (motobecanes at least). Normal Dellorto jets don't work on it. If you want a smaller size jet, you'll have to fill one of the larger ones w/ solder and drill to size.
Other than that, it was real nice, and worked well. got a screw to empty the bowl for the winter and everything. not very used at all... had it on a 70cc kit for like 20miles. going with a bigger carb now.
Oh yeah... got a wire mesh Dellorto air filter I'll throw in if you're interested. a little beat up $2.
Is this still available? I'm sick of my leaky gurtner...
oh, click choke or cable?
I've used this carb on 2 moby's; on 50Va and 50L, great success with both, curvy intakes on both. On the Va it needed to be tilted a bit to clear the frame when variated but still worked great.
bump...
