I need a nice A3 for a Tomos Bullet
I need one that I can count on for being a good runner. I need to be able to just swap it out, do some tuning, and go.
Can anybody help me out?
Re: I need a nice A3 for a Tomos Bullet
Bump!
Help me out here . . . I need one . . .
Look for an A35 too. Same bolt pattern and more after market parts for it.
I was thinking of that, but I heard that converting from an A3 to an A35 requires several other modifications. Care to shed some light on this for me?
Timmy Southpark /
i have a tranny... you will need to swap your stator over, bolt on your new top end, then mount.
Email me if interested.
I had a 87 tomos TT bullet, the engine went bad. So I bought a 2001 A35 off of MA for $60. It bolts right up. Really that simple. It does require a A35 coil (box with the spark plug wire). My A3 one wouldn't create any spark. But it's the same carb and I believe exhaust is the same, but if not I have a stock A35 exhaust I can let go for basically nothing. This way you can open your choices up for tomos engines.
And you can usually buy an engine with the coil included
Jimmy,
How much for your bottom end?
Isn't the A35 coil 12 volt vs. the A3 6 volt?
