Magnum air filter, in case can't locate lost one?
Took two days to notice, but somewhere on my test run my stock air filter fell off the Magnum. Looked yesterday some, will continue today, but just in case, has anyone got one? I can't believe I did this.
Re: Magnum air filter, in case can't locate lost o
***VANILLA BLUNDER*** /
make one and up-jet! also, bing carbs on magnums and maxis are the same, just just had different air boxes because the side covers were different, you could probly make a maxi one work if you werent rocking side covers
I have new Maxi ones, if that helps at all.
Kev
A. J. Souza /
Thanks, but I do have a Maxi one, but I'd prefer an original (that I already had, dammit!), as well as an aftermarket one. The aftermarket one requires figuring in a 45* turn to clear the frame.
Still want an original. Spent about three hours so far looking the streets nearby and found nothing.
I think they are the same as a pinto/freespirit, if so I've got some some spares.
Just let me know...
