Re: Vespa variator/hub/clutch parts
Zane F /
stuff you wouldnt be able to tell is missing from the photos:
wodruff keys, brake shoes, brake return springs, bolts to hold the plates together, gaskets, starter clutch springs, axle from the one with the clutch drum, right side wheel mount.
the needle bearings and retainers will need to be moved around from hub to hub if you want to make one of these work.
