I would like to buy a carb. with a removable main jet . There is two types of carbs. One with a fixed jet and one with removable. Have other Express parts to trade.
Thanks,
Raz
Thanks,
Raz
Hey Raz,I might have one.I have an express I am thinking about parting. but I dont know if its a removable jet or not.I tapped it a little when I cleaned it but it didnt come out.So I dont know if I tapped it hard enought or if its a fixed jet.Any idea how I would know?
What do you got for express parts? I need a petcock that doesnt leak.Not sure what else.
Tim
you have to pull on it a bit to take it out.
raz you need a carb from a 77,79-etc dont get on from a 78 that one has a fixed jet in it. had the same problem when i got one.
What do I pull on it with? and mine is an 80 if that helps.
Tim
I know the 81's of a 2-speed w/ the auto choke have screw in jets. I've also seen one that just slide in, but I can't recall which bike that was on. 78's do have fixed jets. The jets cost about $8 from the honda dealer; a set of # drills cost about $5.
