PA50 II parts wanted!
Catherine Anderson /
Good afternoon.
I am looking for the following parts for a Honda 1982 PA50II.
Cable, Front. Brake 45450-148-671 or
Cable, Fr. Brake 45450-148-672
Cable, Speedometer 44830-148-670 or
Cable, Speedometer 44830-148-671 Also loooking for these but not as desperately...
bulb (6V5W)(5006) 34905-383-611 main bulb
Bulb (6V10W) (5001) 34905-148-790 signal light....blinker bulb
Front and rear tires are 2.25 - 17 with a 2.50 - 17 tube in it.
Thank you
C Anderson
c-itdone@care2.com
Raymond Rexroad /
Try westernhillshondayamaha.com.
I just ordered and received a new front cable.
I have a speedometer cable coming from Europe - if it proves to be the correct one, I'll pass along the info.
Tires - I bought a pair, with tubes on ebay for less than $50.
Re: PA50 II parts wanted!
G'day,
I bought the bulbs at Canadian Tire. I did not go with getting a replacement headlight instead i bought a "sealed tractor beam" from again canadian tire (22 $) and stuck that in as a head light. It fits but you need ot jury rig it into place.
Do you need front and back tires? I "might" be able to help you out with tires ... but not hte tubes.
For the brake cables they tend to be pretty rare you could try jury rigging a new one on to it.
I have the same model as you (one with the blinkers) I'm missing the battery cover Grrr (those are rarer then hens teeth to find).
Cheers
Polar
