This is the bottom end I took off the rally sport, I cleaned it up, and put a clutch side cover on it. the other one had a small hole in it. was able to save the gasket. the electrical still looks new in it. also am posting a pic of clutch side with cover off, so you know everything is there. Motor turns over smoothly, bearings seem fine. there is no play at all in piston rod. should be able toi put a top end on it, and take off. check rest of pictures. 60$ shipped.
