WTB: dellorto air mixture screw
Anyone have an extra or know where to get one?
Thanks
Re: WTB: dellorto air mixture screw
What carb? Do you mean the choke/idle adjust screw? If so, they are easier to just make one.
19mm phbg cable choke. i believe its air mix its a tiny brass screw that is kinda set in. The other screw is much bigger with a spring like the idle adjuster on a bing and in the same location pretty much.
still need one if anyone can help air mixture NOT idle adjustment
Thanks
