I'm selling my Blue Suzuki 86' FA50.
The good: It runs awesome, and needs nothing to be a great little moped. Paint and chrome are nice and shiny, and no bodywork is missing or damaged. I recently decarbonized the muffler and motor as well as changed the gear oil, and cleaned the carb. It doesn't leak anything. Compression test shows the motor is in excellent shape. The seat is in good shape but has one small tear about 1.5 long and two other ones about 1/8 in long. I've always store it inside. I would rate it at overall very good condition
The bad: The tail light is cracked, one rear turn signal lens is missing, and the horn does not work. The battery will probably need to be replaced, but you can still drive it and the lights work no problem. They will just dim a bit if you are not on the gas. The cover to the airbox is missing and I am using a foam air filter from an ATV as a substitute.
All this stuff can be found on Ebay, or this site. I'm asking $375. I'll put pics up if I can tomorrow, or I can email them to those interested. Any questions? Let me know.
Reason for selling is I'm buying a motorcycle. :)
