**Engines For Sale**
I have a few Vespa, Motobecane, Sachs, Trac, And Tomos, and a few other engines.
If you are intersted, please email. PRICED TO SELL!!
Kev
Re: **Engines For Sale**
did u ever get prices on those parts i needed?
Still have that A35...does it come with ignition coil, and carb and intake? That will make a big difference (if it is currently running).
Jack, what did you need again?
I still have the A35, but there is no carb. It appears there is some bearing noise as well.
Please just make me an offer!!!
kev
what do you have for puch
preferrably two speed but either will do
And this is probably a waste of time but do you have a vespa 90 or higher engine, pretty much anything for a smallframe.
I have a Puch e50 that is really rough. It looks like it was sitting outside! It needs some work, and I was going to work on it, but I will sell it.
For Vespa, I have a Grande engine, and a Ciao engine.
kev
kev, I got your email.
I forgot, do you have a full Motobecane motor (av7 or av10) or a very nice/clean looking variator?
thanks man i need the
spring with the balls in it part of the clutch
the cable that allows one to start the moped, it pulls the lever on the clutch, left handlebar
gas cap batavus VA
the big exhaust header for the batavus, or once from a 2 piece biturbo
back half oof a biturbo, rust ok, and doesnt need baffle, or any other performance pipe that was cut up or is cheap, expansion chamber must be good though
batavus side covers for the clutch X1
spring in clutch big one in center
cylinder for m56, and rings, and piston, and circlips, and head
base gasket for m48
price individually please as i probably wont have enough money for all, thanks so much
Kev, what did you want for that e50?
Tim
I'm interested in what puch stock cylinders you have, email me.
Mark, Is that the engine off a 51v?
Jack, yes, I have to check on that still.
Tim, for the real rough e50 - $25+ shipping
The stock Puch cylinders are sold. I may have another if the Tim doesnt want the engine
Kev
Kev, can you give me a little more detail. Is it seized? Hows the cylinder and piston? What parts are missing. I am very interested.
Tim
Kev, ya the AV10 is the reed valve European Motobecane motor.
Sachs 504?
and/or 505/D?
How much for a batavus or Motobecan engine running?
Thanks!
I have a Sachs 505-1A
Also, I have the 51 V engines that look like they would run.
kev
Do you have any Minarelli V1s?
I have one here right now, but it is siezed. $40+ shipping. Or, I can work on it, and it would be a little more if it get it unstuck.
kev
Cool...My friend is looking for one so I'll let her know.
Ok,
Thanks
kev
Email me about that 51v. Any info about and do you have a carb/intake/exhaust for it?
Lets see, we sold the Tomos and the Grande engine
Still have the following
2 Motobecane 51v engines
Trac engine
Sachs 505-1A
Knock off Chinese? version of the Sachs 505
One more Tomos A35
PA 50I engine
Ciao engine
Seized V1
and maybe another.
Please email if you are intersted
kev
how much for the seized V1?
40+ shipping.
Kev
If you still have that seat, headlight and speedo will $100 cover for all the parts?
Bat engines?
Kev?
KEV. I want a 51V Motobecane motor.
Are you positive it's reed-valve case-inducted AV10?
Dan
how much for the Sachs 505-1A?
Kev, The trac motor? Is it a m-56? Also I'm interested in some parts for a trac eagle. speedometer?
