FS: Parts Parts Parts Parts! (Motobecane/Tomos)
Will have a longer list later with pics, but just getting a general consenscious now as to what people are interested in:
I have.
2 Gurtner Carbs (gorgeous condition) (one has cracked airbox)
1 Stock Exhaust
1 COMPLETE FRAME black, tank is rusty.
1 Petcock
2 heads
1 cylinder
2 pistons
1 crankshaft
1 DiMoby clutch
4 case halves (2 complete crank-cases)
1 set of USED motobecane crank bearings 2000k
1 set of handlebars
1 set of handlebar clamps
1 set of front forks
1 swingarm
2 chrome tool-box covers w/nuts
1 white toolbox
1 rear rack (black)
1 set of rear shocks
1 Huret speedo and gear drive (no cable) glass is broken but have pieces.
1 pedal shaft
1 pulley w/bearings and sprockets
2 pedals
1 rear sprocket
Some tomos parts for sale as well:
1 TTLX tank (good condition) NO PETCOCK non-locking gas-cap (PRIMER)
1 swingarm
1 set of shocks (spray bombed gold and black but are OK)
1 TTLX FRAME
2 TTLX fork tubes, springs, and lower shock (tripple trees available but in poor condt)
2 TTLX racks
1 TTLX front fender (spray bombed will primer)
1 TTLX seat, minor cuts in side HAVE COVER TO RE-COVER.
2 TTLX oil-injection systems
2 TTLX glove-boxes
1 TTLX rear fender
2 TTLX dash-boards
E-mail supermandan03@yahoo.com with any offer on any parts.
Dan
Re: FS: Parts Parts Parts Parts! (Motobecane/Tomos
I'll take the Huret speedo drive... name your price.
I'll email you in a bit...
Justin
You say one carb has a cracked airbox... does the other have a whole one, or none at all? I would be interested in buying both the airboxes if you'll separate them from the carbs, otherwise maybe just the carb w/ good airbox.
Does the tomos moped frame have a title if so how much? And much for the tomos front fender and how much is shipping?
Justin: E-mail sent.
Tony: Both carbs are complete, airbox, filter, all nuts and bolts, jets, floats, filter, slides, and spring. One carb has a hole/crack in the black-box where the nut holds it to the carb. There is a large washer on it now that does a good job of holding it on. I do not want to seperate the carb from the airbox. Sorry.
Dave: In Mass we don't have titles, however the VIN is clear and the frame is in good order. I'd imagine if you want, you could use another bike (donor bike) with a titled vin and simply swap it over to this frame.
Let me know. e-mail me replies supermandan03@yahoo.com
Thanks.
Dan
How much for the carb with whole airbox? (Also, how much for carb with cracked airbox?) Also, are we talking 30 mph 50V carbs here, or something else-- what's the outer diameter of the intakes they fit on?
Thanks Dan... I got your email... let me know : )
Justin
Both carbs came off of the "fast" Moby intake. I believe it's 14mm? I don't know the exact dimensions, but it's the thick, aluminum, s-shaped intake.
I also have one of those intakes i can part with as well.
For both carbs and 1 intake... 70 bucks.
Carb with non-cracked airbox 35. Carb with cracked airbox 25. Intake 10 bucks.
5 dollars shipping tagged onto indvidual parts or one, single combined package.
Dan
E-mail sent. But I forgot to mention in it I would also like the petcock. Do include the price there also.
How much for the tomos front fender?
TOMOS LOT HAS BEEN SOLD! Sorry fellas!
Motobecane lot has been thinned:
2 heads
2 pistons
1 crankshaft
1 DiMoby clutch
1 swingarm
1 white toolbox
1 pedal shaft
2 pedals
1 rear sprocket
1 Front fender with supports
Dan
How much for a head and the pedals? Shipping would be to 44730.
need tomos cylinder and head
Tomos Parts Lot Sold! Sorry.
Will get back to you on moby pedals!
Dan
