WTB: Motobecane Wrist Pin Needle Bearing
If someone has an extra one I need it in a bad way everywhere I've tried to order these fuckers from is out and the bearing company I usually order replacement bearings from can't get the right size in. Drop me an email I will give you dollars.
thanks,
scott
Re: WTB: Motobecane Wrist Pin Needle Bearing
10 bucks to your door.
It came out of a 50V with 1800 miles on it, can't tell it from a new one.
Dan
(Can that bearing company get main-bearings for a 50V?)
Email sent.
_Can that bearing company get main-bearings for a 50V_
The answer is no, there're a lot of postings regarding main bearings for the Motobecanes.
I know that... he said he got a lot of his bearings from a specific company, hence, I didn't know if this was a local-shop that just takes a bearing with the same dimension and cuts a chamfer onto it so it could fir the crankshaft.
I know no one 'sells' them... but I didn't know if the shop he refered to was a manufacturing shop.
Sorry for the confusion...
(I may have a lead on some from canada.. so i'll let you know how that works out.)
Dan
