Sachs clutch cable
Mine is busted and the cable cannot be replaced locally. Bicycle cables just don't cut it. Anyone out there have a Sachs clutch cable they don't need?
Sachs clutch cable
roadent$ craig /
i put a bicycle one in mine when i had a sachs...worked fine
Re: Sachs clutch cable
wha??? which bicycle cable did you use?? ie. derailer, brake etc.
i'm REALLY angry at this point, just did a bangup job on my engine that only took about 1hour20minutes of actual labour, but threading the cable through the clutch handle takes over 3 hours then didn't work. that's what I really hate about these mopeds, the mechanically difficult parts are sooo easy once you do it a few times but the easy parts take forever. ****
lol
i've never taken more than 3 minutes to thread the cable through the handle...
As for the clutch cable
I've used derailer cables before
they work, but lasted a very short time
some have had better luck
go to home depot/lowes and get a few feet of galvanized (not stainless) 1/16" wire rope (only .02mm thinner than the stock 1.6mm)
heat the old cable end with a heat gun until the old cable comes out
slather the new cable with appropriate flux
solder onto old cable end
good to go
i'm actually using my old sachs bing throttle cable right now
just strung straight through the old cable end without soldering
what about the end piece at attaches to the clutch itself?
ohhhh i didn't see the soldering part. so a simple soldering job will hold this clutch cable together?? i pull pretty hard
