I GOTTA GET A STOCK PISTON AND RINGS FOR MY PUCH CAN ANYONE HELP A PEDDER OUT
I NEED PISTON,RINGS
Re: I NEED PISTON,RINGS
I have a set; used piston and new rings, 35$ plus shipping
I have brand new Puch pistons for $25.00 + $4.00 shipping, but i only have #3.
Ike
www.ikesbikes.com
hey ike, do you have three of them or what is #3 and is that is a stock 38mm part if so how do you want to proceed with this transaction email the details
you need to match the numbers to the particular engine that you have. It should be stamped on the engine.
Yes i have more than three. And the #3 is the sorting number. You would need a cylinder with #3 on it for this piston to be correct. There are 5 sorting numbers for the aluminum/ chrome bore cylinders. #1 #2 #3 #4 and #5.
The high torque cylinders have #11 #22 and #33 on them.
The numbers on the piston and cylinder need to match to be a perfect fit.
Ike
