WTB Puch 2speed gasket+bolts
does anyone have a gasket and the philips screws for the clutch side cover mine are stripped and gasket is shot .if noone has there here doesw anyone know where to get them thanks
Re: WTB Puch 2speed gasket+bolts
theres a special procedure to replacing the clutch gasket on a 2 speed. It requires shimming the bearings based on the thickness of the new gasket, otherwise there will be bearing play on the transmission mainshaft. you need special measuring tools and shims to replace it. check the service manual, its pretty well described in there.
