Batavus Key Ignition
I NEED ONE WITH A KEY! I dont want to go through the trouble of rerouting every wire and then undoing that work when I get an igntion for EXPENSIVE prices from the factory. So if anyone could help me, thatd be great.
Re: Batavus Key Ignition
I mean just the ignition, not a whole moped.
Did you get my email?
No, I didnt actually, what did it say?
I asked if you wanted me to throw in the petcock with the clutch stuff for an extra 5.00 also that I thought I could make you a clutch cable as the casing I have is still good and I should be able to cut a end off a spare brake cable for it to work. I would throw this in for free, And you might try a tractor repair shop for a Used key Ignition out of a old junker. Let me know
I will take the starter cable, i am not totally sure yet if I need the petcock.
OK
Thanks alot
BUMP
