Kriedler countershaft bearing
I an in need of a Countershaft bearing, (the one next to the sprocket) for a MP9. Anyone have a clue on where to get one. I did a google search and found a website over in Holland or somewhere but I have no way of knowing what part is what from their lists. Maybe if I had the right part number I could find it also. The dimensions are 15 id 35 od 12 wide. This bearing is available all day long 11 wide the oe bearing also has a oil seal incorperated instead of the more common dust shield. Any leads would be appreciated.
Re: Kriedler countershaft bearing
The original part number is 01.00.35 .The bearing should be marked Fafnir 202 K X 3 /C3.
Chris MWH
www.mopedshop.com
Thanks Chris, you wouldn't happen to have one would you?
The Kreidler parts place over in Europe does NOT have this bearing available.
Mike, I have not too many kreidler parts but I'll take a look and see what I can come up with. Surprised they did not have it. I thought they had everything still. One way or another we'll come up with something.
Chris MWH
www.mopedshop.com
I got the Kreidler all together and running, used a new bearing and made my own 1 mm spacer, everything went together easily and it is one sweet ped, I haven't ridden all of the two speed mopeds out there but of the ones that I have ridden the Kriedlers are the best. Now I need a speedo cable.
Here is a photo of the Kreidler.
