WTB: Vespa SI Ignition Coil
Hello,
I need a coil for a 1980 Vespa SI I'm working on right now.
It must match the one in the pic I attached to this post.
Name your price and we'll get er done.
Justin
Re: WTB: Vespa SI Ignition Coil
Ooops - heres the pic of what I need.
Thanks in advance.
Justin
Chances are that a Bosch type coil will work fine. I'll check this afternoon as there is a Grande, two Puchs and a Sachs in my shop.
Sounds good. Let me know.
I would think the one on the Grande would be the same. I sold my cherry Grande a few months ago or I would know for sure...
Thanks,
Justin
Both coils show between 2-3 ohms across terminals (spade terminal to core frame on Vespa), Bosch shows 5.2K ohms terminal to plug lead (no plug cap), Vespa shows 6.2 k ohms. Drill mounting holes to fit the Bosch coil, ground the second terminal, and, as the manual says, reverse procedure to assemble.
Looks the same as your pics.
So I have to drill? I'm reluctant to do that...
Can you post a pic?
Gonna go for the day soon, so I may take some time to get back with you...
Have a good weekend.
Justin
The mounting bolt spread is wider on a Bosch coil. You will figure out what you can find, what you can afford, and what you will do.
I have the stock coil used and working condition for $40.00.
You can email me at mcornell3@wi.rr.com.
I look at this page once /month.
Gerald Langworthy /
I'm looking for an ignition coil for 1974 Vespa ciao. Anything that is compatible would be appreciated.
Gerald... I have two or three good vespa coils.... will email you
