WTB - 1 Puch Top End Mounting Bolt
I need one top-end mounting bolt. And in case I'm not describing it correctly, it's one of the four bolts that you slide the cylinder and head onto.
It's a '77 2HP Puch Maxi.
Thanks.
:M
Re: WTB - 1 Puch Top End Mounting Bolt
jerry bromflieg /
Hi M,if you really cant find one a piece of 6mm studding will do,although some Puch models have 7mm which could be a problem.However if dont like the idea of it being threaded all the way up try to find a 6mm shoulderd bolt or screw thats long enough,cut the head off and cut a new thread for the other end,good luck anyway,Jerry.
Want to reply to this thread?
