Cleaning out my folk's garage and these need to go asap.
MOPEDS – 1978? Vespa (piaggo) bravo, blue
1980 Motobecane Seabring, silver
bolth peds have been sitting outside for 8+years, neather worked when parked. I would say they both need a complete restoration, everything is verry stiff (they don’t even roll smoothly) all cables are stiff, engines are not seezed (I think I checked). Bolth have some rust but none completely through that I can tell. Have titles for both
MOTORS – small tiller, worked when put away (in garage) decent shape, probably
just needs spark plug / carb clean / gas to run
-- snow blower, stopped running, don’t know why, dose'nt snow blow verry
well but worked Ok
-- Briggs + Stratton 3.5HP lawn mower engine, dosent run,
SUNROOF – off a 79 datsun 210, in decent shape, I cleaned up and was going to put it on another car but decided not to. Diddent leak at all when it was on the datsun. Simple mecanical pop open, tinted glass, or you can take the glass out easily by pulling 2 pins.
All this is going to the junk yard in 2 weeks, it will all be on the bulavard starting in about 5 days (10/27), befour then e-mail me if you want something. I will update every night if things are gone. I'll try to find the titles for the mopeds and put them in some plastic bags with the peds, otherwise knock on the door. If you ARE COMPLETELY SURE you want something, e-mail me and I'll put it aside for you. I'll be at the house Tue, Thur, Fri, Sat, Sun, daytime hours (its my parents house, I'm working there) so if you would like some more info stop by then.
The address is:
3018 Zarthan Ave. South
St. Louis Park, MN
55416
