Need up-grade or Turbo exaust for 2003 Kinetic TFR
i have attached a Pic of a Kinetif TFRS USA model ; looking a turbo or up graded exaust system; or a method to make it Run faster; thanks
Re: Need up-grade or Turbo exaust for 2003 Kinetic
you are the TFR salesman, and you cant find one? Go to the links and I think it's either 77mopeds.com or mopedwarehouse that has a polini pipe for TFR. Vespa Ciao pipes will fit also. I had this polini pipe on my tfr and it would do a strong 38-40 with a 55 jet in the carb, but then it fell apart for no reason. This pipe has a bad rep from what I gather. I was going along about 35 on smooth flat ground and the pipe just split, cracked, and fell off my moped. That's the only pipe I know of for the TFR. I wouldn't ever buy the pipe again, but it did work damn good before it fell apart.
Well thanks a lot. yes i am a TFR seller. but the Pipe they claim is an up grade does not do the Job. thanks so much. i appericate it. Jimmie
Want to reply to this thread?
