Ill take 8 of the NGK spark plug caps, the magura pivot bolt and nuts(lot), magura brake levers(4), the magura return spring lot, the 3 of each of the magura horn and on/off base switches(the plastic magura kind only), all the puch oil fill plugs for 2 gears, 2 415 chains with applicable master links, 179-182, 2 of each bing part, at least 2 complete banjo fitting/ fuel inlet assemblies, and 2 qts of amsoil if its premix synthetic. puch bi turbo, 2 of each puch condensor and points, all the kick stand springs, both sets of puch gas tank decals, the lot of puch front and rear brake cables(6 total) then a 6 of each cable holdfast and extenders, that is it, big order, give me a total, I'll email you as well, thanks for taking the time to get this all together.
