Ignition Switch
I am looking for an ignition switch for a 1978 Honda Express, It mounts in the headlight housing...It must be from a 1978 or 1979.....thanks, Armand
Ignition Switch
The ignition from my 1980 won't work??
Re: Ignition Switch
It's possible Rob, Did the 80 have direction signals (blinker)?
Re: Ignition Switch
Yes, it did
Re: Ignition Switch
The switch I have in the 78 now is from a 1980 and I cannot get the headlight going. I will check into the one I have and there is a possibility that the switch is defective. If so, I will give yours a try...I will let you know Rob and thanks, Armand
Want to reply to this thread?
