Vespa parts needed
I need as many of each of these as I can get my hands on unless the quantitly is specified.
1. Ciao center cover bracket (2 needed)
2. Ciao front brake drum complete for springed model(2 needed)
3. Variator spacer (part 77 in attachment)
4. Variator lock washer (part 70 in attachment)
5. Variator nut (part 69 in attachment)
6. rear hub gasket (2 needed)
7. toolbox doors 2
8. Bravo rear turnsignals
9. engine nuts washers, and bolts.
10. flywheel plugs (2 needed)
11. carb thotle cable guide tube
12. the washer with teeth to hold the deco cable to the engine.
13. Ciao cable cover (goes on underside of the tank) (1 needed)
14. horn button. square type that goes on underside of right side controls (2 needed)
thanks,
-Zane
Want to reply to this thread?
