need jawa carb bowl gasket
hey-
anyone have a bowl gasket for a jikov carb????
the bikes a 207
Re: need jawa carb bowl gasket
Just go to your local auto supply store and get some gasket material. Trace the outer edge of the carb on it and use a razor to cut the pattern out. Liquid gasket material may work as well, but I haven't used that, so I couldn't help you there.
And worse comes to worse, the Jikov 2912 and 2909 (from the 210 and 207 respectively) are close to identical minus a few things. If you need a gasket, the one from either of these should work just fine.
you supra???
eh?
Want to reply to this thread?
