more puch parts
ok i got
grips $2.50
handilbars$15.00
speedo$20.00
speedo holder$5.00
forks$20.00
tank$35.0
gas cap$2.50
frame $30.00
swing arm$20.00
springs$15.00
side covers $$15 each or $30.00(boath)
lower side covers $30.00($15 each or $30boath)
brake levers and atach ments $25.00(boath)
wiring harness and swiches $15.00
rims tirs brakes and axels$60.00(each or $100 for boath)
I got more stuff just ask!
Re: more puch parts
Re: more puch parts
Would this be from a Maxi? If so I would be most interested in the Harness.
Re: more puch parts
Which moped are these parts for?...interested in the switches...pleaser send a picture...thanks-oliver
Re: more puch parts
a magnum.
Re: more puch parts
i think that the harnes is the same the onley thing that is diffrent is the swiches.
Re: more puch parts
dern, thanks anyway.
more puch parts
Do you have a decent Maxi chromed rear carrier with lite rust ? Also need a working black tip stoplight switch ! Thanks, Hoot63
Re: more puch parts
theas parts are for a magnum so no.
Re: more puch parts
bump
Re: more puch parts
dude boath is BOTH
Re: more puch parts
what are puch decals sealed in the puch baggies worth?
Re: more puch parts
i need a coil for a 1977,would u have one
Re: more puch parts
still in need of a carb!
Re: more puch parts
i got carb and coils coils$15 carbs $25 12mm right.
Re: more puch parts
any rust in the tank or dents?
Re: more puch parts
77 maxi or newport petcock?
Re: more puch parts
I'll take your grips and gas cap, if the cap still has the seal andd the cup.
--drew.
Re: more puch parts
Allen Midwood /
I would like a tank for a puch magnum II and i would like the metal light/horn and kill switches if you have them..... e-mial me w/ the prices........ - Allen......... sirwamolot@yahoo.com
Re: more puch parts
the tank has rust and one dent it comes with the stuff to remove the rust thoe.
Re: more puch parts
Can i get the carb
more puch parts
do you still have the front forks? can you tell me if the paint is green? any pics?
i need the front forks, front fender, headlight/turnsignal switch, rear tail light lense, and fuel petcock if you still any of the parts.
thanks
Dan
