Anyone near Hardeeville SC
Hardeeville according to maps not far from Savannah and Hilton Head I always get stuck in the middle of nowhere not in like myrtle beach where I know people
Stuck in a parking lot need a bit of help the clutch in my ranger broke
Did the horrible job of putting a new one in on the ground with very little tooling I'm out of ideas it won't release and the master and slave is good and working
I don't want a repeat of 2009
Re: Anyone near Hardeeville SC
What year ranger? When I did my clutch I remember it being a motherfucker to bleed the cylinder enough to work
It's a 2000
The slave and master are only a month old and are working the pedal is hard
Something is jamming up
I'm in the middle of tearing it apart again wishing I had a floor jack I only have 2 old scissor jacks making a hard job even harder
I hate cars
Did you replace or at least inspect the throw-out bearing?
Throw out bearing is part of the slave which is a month old
I wish I replaced the clutch at the same time but I'm an idiot
What's up Jay! Been along time
Same shit as usual
Only thing left is the fingers on pressure plate. Be sure to get flywheel turned while you're in there. (edited)
The first time I did it I couldn't get the trans Bak enough to get the pressure plate out so I tried to just replace the disc
Then my buddy Georgie Reynolds drove down from Myrtle Beach and brought me a floor jack which is a lot stronger than I am so I got the trans back far enough so I can get the new pressure plate in
The flywheel is surprisingly smooth and evenly worn according to my not so good eye but good enough for the rest of the drive
Still would rather be doing this than messing with a slipping automatic for everyone who argues that automatic is better which it's not
Oh and the strange reason the clutch failed it wasn't worn out or slipping at all the spline hub stripped out
It was a not very lucky LUK clutch and unfortunately I have to replace it with the same clutch cause that's all that was available locally
Make sure you're not putting the disk in backwards
You're like the 10th person that said that it's impossible to put in the Ford clutch backwards it only fits in one way
It's back together and working now
Not impossible at all..that has been done lots of times...you would not be the first
...glad you got it going
There's no way if you try to put it on backwards it won't sit against the flywheel and the pressure plate ain't going on
It's running as good as its gonna for a ranger with almost 300,000 badly abused miles on it
