Re: Another new bike
Yo Man /
Digging your build.
I have been following it for a bit.
If you don’t mind I have a few questions.
And a few suggestions…
Did you gusset the hard tail? If not run two “L”brackets on the top. It will also be a good mount set up for your seat.
I’ve never done a sportster but does the bottom bolt to the motor?
Because for some reason I was thinking the motor bolts to the backbone/seat post and front down tubes?
So, is the bottom of the frame just a bolt together?
If so I would run a rod/slug through it then weld it.
I have seen bolt together hard tails break and I’ve also seen bagger bolt together raked necks break and that would suck.
One other thing while your welding and cleaning things up, you should just weld a 1/4 inch thick by how ever wide “L” bracket to get rid of that bolt together rear brake lock to clean up that side of the frame.
I just eyeball it to make sure the caliper is centered and that there is enough room for the 90deg for the brake line.
Great work and can’t wait to see the finished bike.
  Another new bikeTopic by: Satan 666 Satan 666 10/05/21 11:22AM
  Re: Another new bikeRe: Satan 666 Satan 666 10/05/21 03:43PM
  Re: Another new bikeRe: Beach Club Nick Beach Club Nick 10/05/21 04:28PM
  Re: Another new bikeRe: Pushrod Fifty Pushrod Fifty 10/05/21 07:55PM
  Re: Another new bikeRe: Satan 666 Satan 666 10/05/21 08:57PM
  Re: Another new bikeRe: Satan 666 Satan 666 10/05/21 09:00PM
  Re: Another new bikeRe: Satan 666 Satan 666 10/05/21 09:18PM
  Re: Another new bikeRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 10/06/21 10:13AM
  Re: Another new bikeRe: Born to be WillD Born to be WillD 10/06/21 10:19AM
  Re: Another new bikeRe: Satan 666 Satan 666 10/06/21 10:41AM
  Re: Another new bikeRe: Satan 666 Satan 666 10/11/21 09:05AM
  Re: Another new bikeRe: Pops Peds Pops Peds 10/11/21 09:38AM
  Re: Another new bikeRe: Satan 666 Satan 666 10/11/21 09:10AM
  Re: Another new bikeRe: Satan 666 Satan 666 10/14/21 09:53PM
  Re: Another new bikeRe: Satan 666 Satan 666 10/25/21 11:28AM
  Re: Another new bikeRe: Satan 666 Satan 666 10/25/21 11:34AM
  Re: Another new bikeRe: Stephen Keller Stephen Keller 10/29/21 10:56PM
  Re: Another new bikeRe: Satan 666 Satan 666 10/29/21 12:57PM
  Re: Another new bikeRe: Born to be WillD Born to be WillD 11/01/21 11:16AM
  Re: Another new bikeRe: Satan 666 Satan 666 11/01/21 12:16PM
  Re: Another new bikeRe: 🎨🏆 Duncan 🎨🏆 Duncan 11/01/21 03:42PM
  Re: Another new bikeRe: Satan 666 Satan 666 11/01/21 06:51PM
  Re: Another new bikeRe: Born to be WillD Born to be WillD 11/02/21 01:07PM
  Re: Another new bikeRe: Satan 666 Satan 666 11/02/21 01:32PM
  Re: Another new bikeRe: Stephen Keller Stephen Keller 11/02/21 08:17PM
  Re: Another new bikeRe: Rich Allen Rich Allen 11/12/21 05:18PM
  Re: Another new bikeRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 11/12/21 09:10PM
  Re: Another new bikeRe: Brian Solex Brian Solex 11/14/21 05:09PM
  Re: Another new bikeRe: Born to be WillD Born to be WillD 11/15/21 09:26AM
  Re: Another new bikeRe: Satan 666 Satan 666 11/15/21 10:40AM
  Re: Another new bikeRe: Satan 666 Satan 666 11/13/21 06:45AM
  Re: Another new bikeRe: Satan 666 Satan 666 11/13/21 11:53AM
  Re: Another new bikeRe: Stephen Keller Stephen Keller 11/13/21 10:44PM
  Re: Another new bikeRe: Satan 666 Satan 666 11/14/21 05:21PM
  Re: Another new bikeRe: Brian Solex Brian Solex 11/14/21 07:48PM
  Re: Another new bikeRe: Satan 666 Satan 666 11/15/21 08:24AM
  Re: Another new bikeRe: Brian Solex Brian Solex 11/15/21 08:45AM
  Re: Another new bikeRe: Rich Allen Rich Allen 11/15/21 07:16PM
  Re: Another new bikeRe: Brian Solex Brian Solex 11/16/21 08:25AM
  Re: Another new bikeRe: Satan 666 Satan 666 11/16/21 09:18AM
  Re: Another new bikeRe: Rich Allen Rich Allen 11/16/21 06:19PM
  Re: Another new bikeRe: Satan 666 Satan 666 11/16/21 07:19PM
  Re: Another new bikeRe: Brian Solex Brian Solex 11/17/21 08:29AM
  Re: Another new bikeRe: Satan 666 Satan 666 11/17/21 11:21AM
  Re: Another new bikeRe: Satan 666 Satan 666 11/15/21 10:43AM
  Re: Another new bikeRe: Rich Allen Rich Allen 11/17/21 04:18PM
  Re: Another new bikeRe: Brian Solex Brian Solex 11/17/21 04:53PM
  Re: Another new bikeRe: Rich Allen Rich Allen 11/17/21 06:48PM
  Re: Another new bikeRe: Satan 666 Satan 666 11/17/21 08:15PM
  Re: Another new bikeRe: Satan 666 Satan 666 11/21/21 09:13AM
  Re: Another new bikeRe: Brian Solex Brian Solex 11/22/21 02:05PM
  Re: Another new bikeRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 11/22/21 06:14PM
  Re: Another new bikeRe: Pops Peds Pops Peds 11/23/21 08:47AM
  Re: Another new bikeRe: Satan 666 Satan 666 11/22/21 08:56PM
  Re: Another new bikeRe: Satan 666 Satan 666 11/24/21 02:45PM
  Re: Another new bikeRe: Born to be WillD Born to be WillD 12/07/21 03:22PM
  Re: Another new bikeRe: Satan 666 Satan 666 12/05/21 07:17AM
  Re: Another new bikeRe: Brian Solex Brian Solex 12/08/21 07:49PM
  Re: Another new bikeRe: Satan 666 Satan 666 12/08/21 08:41PM
  Re: Another new bikeRe: Satan 666 Satan 666 12/10/21 06:30AM
  Re: Another new bikeRe: Brian Solex Brian Solex 12/10/21 06:11PM
  Re: Another new bikeRe: tom toczek tom toczek 12/10/21 09:05PM
  Re: Another new bikeRe: Satan 666 Satan 666 12/11/21 06:28AM
  Re: Another new bikeRe: Satan 666 Satan 666 12/14/21 07:22PM
  Re: Another new bikeRe: Pops Peds Pops Peds 12/15/21 12:26AM
  Re: Another new bikeRe: David Shearouse David Shearouse 12/15/21 01:23AM
  Re: Another new bikeRe: Graham Motzing Graham Motzing 12/17/21 05:57PM
  Re: Another new bikeRe: Satan 666 Satan 666 12/17/21 06:25PM
  Re: Another new bikeRe: Stephen Keller Stephen Keller 12/17/21 08:44PM
  Re: Another new bikeRe: Satan 666 Satan 666 12/17/21 06:20PM
  Re: Another new bikeRe: Stephen Keller Stephen Keller 12/17/21 06:24PM
  Re: Another new bikeRe: Satan 666 Satan 666 12/17/21 06:30PM
  Re: Another new bikeRe: Satan 666 Satan 666 12/18/21 08:45AM
  Re: Another new bikeRe: Graham Motzing Graham Motzing 12/18/21 10:03AM
  Re: Another new bikeRe: Satan 666 Satan 666 12/18/21 11:27AM
  Re: Another new bikeRe: Graham Motzing Graham Motzing 12/23/21 11:17AM
  Re: Another new bikeRe: Graham Motzing Graham Motzing 12/23/21 11:45AM
  Re: Another new bikeRe: Satan 666 Satan 666 12/19/21 09:28PM
  Re: Another new bikeRe: Born to be WillD Born to be WillD 12/23/21 10:08AM
  Re: Another new bikeRe: Satan 666 Satan 666 12/23/21 12:20PM
  Re: Another new bikeRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 12/24/21 03:55PM
  Re: Another new bikeRe: Satan 666 Satan 666 12/25/21 06:32AM
  Re: Another new bikeRe: Satan 666 Satan 666 01/03/22 05:47PM
  Re: Another new bikeRe: Satan 666 Satan 666 03/18/22 07:08PM
  Re: Another new bikeRe: Graham Motzing Graham Motzing 03/18/22 07:47PM
  Re: Another new bikeRe: Satan 666 Satan 666 03/18/22 07:13PM
  Re: Another new bikeRe: Satan 666 Satan 666 03/18/22 07:21PM
  Re: Another new bikeRe: Satan 666 Satan 666 03/18/22 07:23PM
  Re: Another new bikeRe: Yo Man Yo Man 03/18/22 08:44PM
  Re: Another new bikeRe: Satan 666 Satan 666 03/18/22 09:55PM
