Onan 16hp twin cylinder engine. B43, P218
anybody into these lawn tractor engines.
i need parts for rebuild a couple i have in the shed. (edited)
Re: Onan 16hp twin cylinder engine. B43, P218
I would never stop mowing the lawn.
Right? :)
Most of the stuff you need can be found on ebay. Check your intakes, these engines have an intake cast in two pieces, and they are pressed together with sealant in between. Due to age many are leaking or starting to come apart. You can split the halves, drill out the pins to match the existing holes and use small screws to hold the halves together. I used non hardening sealant like you would use on puch cases.
