Re: PC build question
fox -+:| /
they are standardized
most case fans protocol are using "molex"
psu (power supply units) come in modular, semi modular, or standard (rats nest/cheap) and provide extensions for your fans, sometime the fans daisy chain into a single molex port. the other type of power connector is for sata power (for drives and stuff).
non molex type fans that have 4 lanes are pwm (power watt management). these need to be plugged into the board so that the system can send given amounts of power based on ambient temps or load. i have used molex adapters to these and just put them on open ends on the psu, which unfortunately removes the pwm feature and just has the fan run full blast unless hooked into an external controller.
the mobo fan terminals are dedicated for the cpu usually. it appears u have a gigabyte board, which supports pwm. i only run my case fans from psu, and opt to buy the brand: Noctua now, just my preference
if pwm is a feature you really want, there are some pretty cool fan controllers out there, or just use something simple, cheap, and effective like this one (assuming you have a spare molex power off your power supply open. the pwm connector at the end of the board i linked goes to your mobo system fan terminal (i would plug ur cpu fan directly into the cpu fan terminal on the mobo, and not mess with this adapter except for case fans)
my guess is that the board cant route all that power to all those case fans chained together like that. direct from psu you should be good (edited)
  PC build questionTopic by: Papa _ Papa _ 01/11/21 03:03PM
  Re: PC build questionRe: Nick MBC Nick MBC 01/11/21 03:32PM
  Re: PC build questionRe: UNIT#010 CCC UNIT#010 CCC 01/11/21 07:22PM
  Re: PC build questionRe: UNIT#010 CCC UNIT#010 CCC 01/11/21 08:01PM
  Re: PC build questionRe: Nick MBC Nick MBC 01/11/21 11:20PM
  Re: PC build questionRe: fox -+:| fox -+:| 01/16/21 08:58PM
  Re: PC build questionRe: Johnny Braaapp Johnny Braaapp 01/16/21 09:58PM
  Re: PC build questionRe: Papa _ Papa _ 01/17/21 03:38AM
  Re: PC build questionRe: Papa _ Papa _ 01/20/21 09:45AM
  Re: PC build questionRe: Johnny Braaapp Johnny Braaapp 01/20/21 09:57AM
  Re: PC build questionRe: Papa _ Papa _ 01/20/21 01:11PM
  Re: PC build questionRe: Johnny Braaapp Johnny Braaapp 01/20/21 01:24PM
  Re: PC build questionRe: Papa _ Papa _ 01/25/21 01:10PM
  Re: PC build questionRe: Nick MBC Nick MBC 01/25/21 01:17PM
  Re: PC build questionRe: Matt Mulligan Matt Mulligan 01/26/21 02:24AM
  Re: PC build questionRe: Papa _ Papa _ 01/25/21 01:37PM
  Re: PC build questionRe: Nick MBC Nick MBC 01/25/21 01:45PM
  Re: PC build questionRe: Papa _ Papa _ 01/25/21 02:08PM
  Re: PC build questionRe: Nick MBC Nick MBC 01/25/21 02:15PM
  Re: PC build questionRe: Johnny Braaapp Johnny Braaapp 01/25/21 02:13PM
  Re: PC build questionRe: Papa _ Papa _ 01/25/21 02:33PM
  Re: PC build questionRe: Papa _ Papa _ 01/28/21 04:26PM
  Re: PC build questionRe: Papa _ Papa _ 01/30/21 03:29AM
  Re: PC build questionRe: niklaus _ niklaus _ 01/30/21 04:33AM
  Re: PC build questionRe: Papa _ Papa _ 01/30/21 04:54AM
  Re: PC build questionRe: niklaus _ niklaus _ 01/30/21 05:16AM
  Re: PC build questionRe: Papa _ Papa _ 01/30/21 05:47AM
  Re: PC build questionRe: Nick MBC Nick MBC 02/11/21 09:44PM
  Re: PC build questionRe: Papa _ Papa _ 02/12/21 02:56AM
  Re: PC build questionRe: Papa _ Papa _ 01/30/21 04:58AM
  Re: PC build questionRe: Nile Muti Nile Muti 02/11/21 09:31PM
  Re: PC build questionRe: __̴ı̴̴̡̡̡ ̡͌l̡̡̡ ̡͌l̡*̡̡ ̴̡ı̴̴̡ ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡͡ ̲|̡̡̡ ̡ ̴̡ı̴̡̡ ̡͌l̡̡̡̡.__ __̴ı̴̴̡̡̡ ̡͌l̡̡̡ ̡͌l̡*̡̡ ̴̡ı̴̴̡ ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡͡ ̲|̡̡̡ ̡ ̴̡ı̴̡̡ ̡͌l̡̡̡̡.__ 02/14/21 02:44AM
  Re: PC build questionRe: Papa _ Papa _ 02/14/21 04:10AM
  Re: PC build questionRe: __̴ı̴̴̡̡̡ ̡͌l̡̡̡ ̡͌l̡*̡̡ ̴̡ı̴̴̡ ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡͡ ̲|̡̡̡ ̡ ̴̡ı̴̡̡ ̡͌l̡̡̡̡.__ __̴ı̴̴̡̡̡ ̡͌l̡̡̡ ̡͌l̡*̡̡ ̴̡ı̴̴̡ ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡͡ ̲|̡̡̡ ̡ ̴̡ı̴̡̡ ̡͌l̡̡̡̡.__ 02/14/21 01:19PM
  Re: PC build questionRe: Pops Peds Pops Peds 02/14/21 03:32PM
  Re: PC build questionRe: Nick MBC Nick MBC 02/14/21 06:55PM
  Re: PC build questionRe: Pops Peds Pops Peds 02/14/21 07:47PM
  Re: PC build questionRe: Nick MBC Nick MBC 02/14/21 07:55PM
  Re: PC build questionRe: Pops Peds Pops Peds 02/14/21 10:22PM
  Re: PC build questionRe: __̴ı̴̴̡̡̡ ̡͌l̡̡̡ ̡͌l̡*̡̡ ̴̡ı̴̴̡ ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡͡ ̲|̡̡̡ ̡ ̴̡ı̴̡̡ ̡͌l̡̡̡̡.__ __̴ı̴̴̡̡̡ ̡͌l̡̡̡ ̡͌l̡*̡̡ ̴̡ı̴̴̡ ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡͡ ̲|̡̡̡ ̡ ̴̡ı̴̡̡ ̡͌l̡̡̡̡.__ 02/15/21 09:32PM
  Re: PC build questionRe: Ѭ ɞŦЯʚOluv Ѫѫ Ѭ ɞŦЯʚOluv Ѫѫ 02/15/21 12:14PM
