Hello,
I've been working on this G30 RV at the same time as my mopeds. I haven't driven it since January 2018 but hopefully I will be able to start the engine again soon.
I'm going to start with a question about the power steering pump hoping that some of you work on Small Block Chevy engines too.
The power steering pump that came with it has this bracket bolted to the front with a little arm that bends over the pulley. The previous owner had a belt on it that was way too loose so it avoided hitting the arm. Now that I have the right size belt on it touches the bracket. Does anyone know what this bracket is for or if I can remove it? My only guess is that it is there so you can stick a pry bar in it to pivot the power steering pump forward to tighten the belt (or at least that's what I used it for).
I posted on a couple Chevy forums but nobody seems to have ever seen that bracket before. Thanks!
These last two photos are from 2018 before I started the restoration.
