Re: My Stimulus is being STOLEN
I’d ask to see this metal that’s in the oil. Did they even bother to test oil pressure? Check for vvt codes? You probably have sucker written across your forehead.
With you stating that you noticed no top end noise after driving it on the highway for 10 minutes, i’m thinking that it has oil pressure.
The oil pump on that motor is driven by the snout of the crankshaft. I just can’t imagine it working one minute, then not working the next. Growing weaker over time maybe, with the oil light flickering at idle as the first signs is a typical failure scenario. The only “now it works, now it doesn’t “ scenario I can think of would be the pressure relief valve on the pump is stuck, which I believe is accessible from outside the timing cover.
Those 3.5L motors clatter like hell after an oil change until the filter fills up, so a no pressure issue would seem obvious to me.
You can remove the oil fill cap and look in there and see rocker arms and watch for oil flying around as it’s running too.
Unless it has obvious vvt noise and vvt codes, I’d have the pressure actually tested before i went any farther. If they don’t have the means to test the pressure, have them replace the $30 pressure sending just above the oil filter and drive the fucking thing.
  My Stimulus is being STOLENTopic by: Papa _ Papa _ 01/03/21 10:56AM
  Re: My Stimulus is being STOLENRe: Probably Fred Probably Fred 01/03/21 11:13AM
  Re: My Stimulus is being STOLENRe: live ɘvil live ɘvil 01/03/21 11:28AM
  Re: My Stimulus is being STOLENRe: Papa _ Papa _ 01/03/21 11:40AM
  Re: My Stimulus is being STOLENRe: Seth B Seth B 01/03/21 11:43AM
  Re: My Stimulus is being STOLENRe: live ɘvil live ɘvil 01/03/21 11:50AM
  Re: My Stimulus is being STOLENRe: Seth B Seth B 01/03/21 12:00PM
  Re: My Stimulus is being STOLENRe: Stephen Keller Stephen Keller 01/03/21 12:00PM
  Re: My Stimulus is being STOLENRe: Papa _ Papa _ 01/03/21 11:52AM
  Re: My Stimulus is being STOLENRe: live ɘvil live ɘvil 01/03/21 11:57AM
  Re: My Stimulus is being STOLENRe: Papa _ Papa _ 01/03/21 11:55AM
  Re: My Stimulus is being STOLENRe: punkrock randy punkrock randy 01/03/21 12:01PM
  Re: My Stimulus is being STOLENRe: punkrock randy punkrock randy 01/03/21 12:04PM
  Re: My Stimulus is being STOLENRe: Papa _ Papa _ 01/03/21 12:12PM
  Re: My Stimulus is being STOLENRe: Stephen Keller Stephen Keller 01/03/21 12:14PM
  Re: My Stimulus is being STOLENRe: live ɘvil live ɘvil 01/03/21 12:17PM
  Re: My Stimulus is being STOLENRe: Stephen Keller Stephen Keller 01/03/21 12:19PM
  Re: My Stimulus is being STOLENRe: Papa _ Papa _ 01/03/21 12:52PM
  Re: My Stimulus is being STOLENRe: Stephen Keller Stephen Keller 01/03/21 01:00PM
  Re: My Stimulus is being STOLENRe: Daniel '' Daniel '' 01/03/21 07:23PM
  Re: My Stimulus is being STOLENRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 01/04/21 05:53PM
  Re: My Stimulus is being STOLENRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 01/04/21 06:04PM
  Re: My Stimulus is being STOLENRe: Michelle Mono Michelle Mono 01/04/21 11:32PM
  Re: My Stimulus is being STOLENRe: Papa _ Papa _ 01/05/21 02:22AM
  Re: My Stimulus is being STOLENRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 01/05/21 07:02AM
  Re: My Stimulus is being STOLENRe: Papa _ Papa _ 01/05/21 07:18AM
  Re: My Stimulus is being STOLENRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 01/05/21 07:25AM
  Re: My Stimulus is being STOLENRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 01/05/21 07:21AM
  Re: My Stimulus is being STOLENRe: Papa _ Papa _ 01/05/21 07:46AM
  Re: My Stimulus is being STOLENRe: Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F 01/05/21 10:31AM
  Re: My Stimulus is being STOLENRe: Papa _ Papa _ 01/05/21 11:00AM
  Re: My Stimulus is being STOLENRe: Seth B Seth B 01/05/21 11:17AM
  Re: My Stimulus is being STOLENRe: Papa _ Papa _ 01/05/21 12:15PM
  Re: My Stimulus is being STOLENRe: Probably Fred Probably Fred 01/05/21 01:05PM
  Re: My Stimulus is being STOLENRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 01/05/21 01:36PM
  Re: My Stimulus is being STOLENRe: Papa _ Papa _ 01/05/21 01:31PM
  Re: My Stimulus is being STOLENRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 01/05/21 01:33PM
  Re: My Stimulus is being STOLENRe: Papa _ Papa _ 01/05/21 02:07PM
  Re: My Stimulus is being STOLENRe: Papa _ Papa _ 01/11/21 02:29PM
  Re: My Stimulus is being STOLENRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 01/11/21 03:50PM
  Re: My Stimulus is being STOLENRe: Papa _ Papa _ 01/12/21 11:42AM
  Re: My Stimulus is being STOLENRe: Papa _ Papa _ 02/26/21 02:24PM
  Re: My Stimulus is being STOLENRe: live ɘvil live ɘvil 02/26/21 05:47PM
  Re: My Stimulus is being STOLENRe: punkrock randy punkrock randy 02/26/21 04:04PM
  Re: My Stimulus is being STOLENRe: Papa _ Papa _ 02/26/21 04:58PM
  Re: My Stimulus is being STOLENRe: Don Ohio Don Ohio 02/27/21 12:49AM
  Re: My Stimulus is being STOLENRe: Stephen Keller Stephen Keller 02/27/21 12:53AM
  Re: My Stimulus is being STOLENRe: Papa _ Papa _ 02/27/21 01:41AM
  Re: My Stimulus is being STOLENRe: Stephen Keller Stephen Keller 02/27/21 11:06AM
  Re: My Stimulus is being STOLENRe: punkrock randy punkrock randy 02/28/21 08:44AM
  Re: My Stimulus is being STOLENRe: Stephen Keller Stephen Keller 02/28/21 01:58PM
  Re: My Stimulus is being STOLENRe: punkrock randy punkrock randy 02/27/21 07:09AM
  Re: My Stimulus is being STOLENRe: Taylor King Taylor King 02/27/21 09:50PM
  Re: My Stimulus is being STOLENRe: Stephen Keller Stephen Keller 02/27/21 10:03PM
  Re: My Stimulus is being STOLENRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 02/28/21 08:54AM
  Re: My Stimulus is being STOLENRe: Papa _ Papa _ 02/28/21 09:09AM
  Re: My Stimulus is being STOLENRe: Papa _ Papa _ 02/28/21 05:20AM
  Re: My Stimulus is being STOLENRe: Papa _ Papa _ 02/28/21 05:32AM
  Re: My Stimulus is being STOLENRe: Johnny Braaapp Johnny Braaapp 02/28/21 07:46AM
  Re: My Stimulus is being STOLENRe: Stephen Keller Stephen Keller 02/28/21 02:03PM
  Re: My Stimulus is being STOLENRe: Papa _ Papa _ 02/28/21 08:33AM
  Re: My Stimulus is being STOLENRe: punkrock randy punkrock randy 02/28/21 08:58AM
  Re: My Stimulus is being STOLENRe: punkrock randy punkrock randy 02/28/21 10:52AM
  Re: My Stimulus is being STOLENRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 02/28/21 12:00PM
  Re: My Stimulus is being STOLENRe: Papa _ Papa _ 02/28/21 01:33PM
  Re: My Stimulus is being STOLENRe: Johnny Braaapp Johnny Braaapp 02/28/21 06:03PM
  Re: My Stimulus is being STOLENRe: live ɘvil live ɘvil 03/14/21 07:03AM
  Re: My Stimulus is being STOLENRe: Pops Peds Pops Peds 03/14/21 07:34AM
  Re: My Stimulus is being STOLENRe: Stephen Keller Stephen Keller 03/14/21 01:07PM
  Re: My Stimulus is being STOLENRe: Pops Peds Pops Peds 03/14/21 04:20PM
  Re: My Stimulus is being STOLENRe: live ɘvil live ɘvil 03/16/21 05:20PM
  Re: My Stimulus is being STOLENRe: Papa _ Papa _ 09/19/21 01:52PM
  Re: My Stimulus is being STOLENRe: Born to be WillD Born to be WillD 09/20/21 04:25PM
  Re: My Stimulus is being STOLENRe: Papa _ Papa _ 03/12/21 03:41AM
  Re: My Stimulus is being STOLENRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 03/12/21 10:25AM
  Re: My Stimulus is being STOLENRe: punkrock randy punkrock randy 03/12/21 06:33AM
  Re: My Stimulus is being STOLENRe: punkrock randy punkrock randy 03/12/21 11:25AM
  Re: My Stimulus is being STOLENRe: Stephen Keller Stephen Keller 03/12/21 12:06PM
  Re: My Stimulus is being STOLENRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 03/12/21 03:19PM
  Re: My Stimulus is being STOLENRe: Papa _ Papa _ 03/12/21 12:00PM
  Re: My Stimulus is being STOLENRe: Papa _ Papa _ 03/12/21 02:21PM
  Re: My Stimulus is being STOLENRe: punkrock randy punkrock randy 03/13/21 01:08PM
  Re: My Stimulus is being STOLENRe: Pops Peds Pops Peds 03/13/21 04:38PM
  Re: My Stimulus is being STOLENRe: Chris Szuba Chris Szuba 03/15/21 12:05PM
  Re: My Stimulus is being STOLENRe: Stephen Keller Stephen Keller 03/15/21 12:52PM
  Re: My Stimulus is being STOLENRe: Papa _ Papa _ 03/16/21 02:53PM
  Re: My Stimulus is being STOLENRe: Ryan Graeme Ryan Graeme 03/16/21 03:24PM
  Re: My Stimulus is being STOLENRe: Stephen Keller Stephen Keller 03/16/21 05:05PM
  Re: My Stimulus is being STOLENRe: punkrock randy punkrock randy 03/16/21 03:56PM
  Re: My Stimulus is being STOLENRe: Papa _ Papa _ 09/20/21 07:55PM
  Re: My Stimulus is being STOLENRe: Stephen Keller Stephen Keller 09/21/21 01:06AM
