Re: Vacuum petcock on scooter, how long should it hold pressure?
live ɘvil /
> Pops Peds Wrote:
> > Born to be WillD Wrote:
> > no the vac line doesn't have gas in it, nothin to leak but air. its a
> > petal valve, there is like a little diaphragm, sometimes its a pumper
> > but usually just allows flow only when the vacuum pulses from the
> > cylinder draw it open, you can bypass it by sucking on the line, youre
> > sucking under the diaphragm on the dry side to draw it "open" and
> check
> > that it lets gas flow any cracks and it loses vacuum and doesn't draw
> it
> > open
> This is about as wrong as wrong can get..the petcock will let gas.into
> the vacuum line...not.my first rodeo on this or googled up second hand
> knowlledge
Will was talking about the fact that there shouldnt be gas in a vacuum line candy ass. I have seen one design that kept the gas from entering the vacuum circuit when the diaphragm failed. You wouldnt be able to afford it though, much less work on it with your sticks and stones.
  Vacuum petcock on scooter, how long should it hold pressure?Topic by: Stephen Keller Stephen Keller 09/07/20 11:07PM
  Re: Vacuum petcock on scooter, how long should it hold pressure?Re: Mark Booth Mark Booth 09/07/20 11:28PM
  Re: Vacuum petcock on scooter, how long should it hold pressure?Re: Stephen Keller Stephen Keller 09/07/20 11:36PM
  Re: Vacuum petcock on scooter, how long should it hold pressure?Re: Mark Booth Mark Booth 09/07/20 11:46PM
  Re: Vacuum petcock on scooter, how long should it hold pressure?Re: Stephen Keller Stephen Keller 09/07/20 11:55PM
  Re: Vacuum petcock on scooter, how long should it hold pressure?Re: Stephen Keller Stephen Keller 09/07/20 11:58PM
  Re: Vacuum petcock on scooter, how long should it hold pressure?Re: Mark Booth Mark Booth 09/08/20 12:12AM
  Re: Vacuum petcock on scooter, how long should it hold pressure?Re: Stephen Keller Stephen Keller 09/08/20 12:30AM
  Re: Vacuum petcock on scooter, how long should it hold pressure?Re: Mark Booth Mark Booth 09/08/20 12:16AM
  Re: Vacuum petcock on scooter, how long should it hold pressure?Re: Thomas TPRF Thomas TPRF 09/08/20 12:41AM
  Re: Vacuum petcock on scooter, how long should it hold pressure?Re: Stephen Keller Stephen Keller 09/08/20 12:52AM
  Re: Vacuum petcock on scooter, how long should it hold pressure?Re: Pops Peds Pops Peds 09/08/20 09:21AM
  Re: Vacuum petcock on scooter, how long should it hold pressure?Re: Stephen Keller Stephen Keller 09/08/20 11:05AM
  Re: Vacuum petcock on scooter, how long should it hold pressure?Re: Thomas TPRF Thomas TPRF 09/09/20 11:47AM
  Re: Vacuum petcock on scooter, how long should it hold pressure?Re: Stephen Keller Stephen Keller 09/09/20 12:46PM
  Re: Vacuum petcock on scooter, how long should it hold pressure?Re: Pops Peds Pops Peds 09/09/20 05:12PM
  Re: Vacuum petcock on scooter, how long should it hold pressure?Re: Graham Motzing Graham Motzing 09/09/20 01:42PM
  Re: Vacuum petcock on scooter, how long should it hold pressure?Re: Born to be WillD Born to be WillD 09/10/20 09:58AM
  Re: Vacuum petcock on scooter, how long should it hold pressure?Re: Stephen Keller Stephen Keller 09/10/20 11:10AM
  Re: Vacuum petcock on scooter, how long should it hold pressure?Re: Pops Peds Pops Peds 09/10/20 11:25AM
  Re: Vacuum petcock on scooter, how long should it hold pressure?Re: Stephen Keller Stephen Keller 09/10/20 11:33AM
  Re: Vacuum petcock on scooter, how long should it hold pressure?Re: Born to be WillD Born to be WillD 09/14/20 11:04PM
  Re: Vacuum petcock on scooter, how long should it hold pressure?Re: Stephen Keller Stephen Keller 09/15/20 12:08AM
  Re: Vacuum petcock on scooter, how long should it hold pressure?Re: Thomas TPRF Thomas TPRF 09/15/20 10:10AM
  Re: Vacuum petcock on scooter, how long should it hold pressure?Re: Pops Peds Pops Peds 09/15/20 09:22AM
  Re: Vacuum petcock on scooter, how long should it hold pressure?Re: Stephen Keller Stephen Keller 09/15/20 10:25AM
  Re: Vacuum petcock on scooter, how long should it hold pressure?Re: live ɘvil live ɘvil 09/15/20 05:37PM
  Re: Vacuum petcock on scooter, how long should it hold pressure?Re: Pops Peds Pops Peds 09/15/20 06:29PM
  Re: Vacuum petcock on scooter, how long should it hold pressure?Re: Stephen Keller Stephen Keller 09/16/20 12:48PM
