Re: Vacuum petcock on scooter, how long should it hold pressure?
Mark Booth /
You are 100% correct. But as stated there is plenty enough fuel in the carb for the initial start to get everything going.
I have a bad memory... I am trying to remember how I checked the auto choke... I think I removed it and hooked jumpers to it from a 12v source. I think I also checked for voltage when starting to see if the auto choke was being given the signal.
If you still think it is the petcock... plug the port where the hose goes into the manifold. Pull a suck on the tube and try to start. If you still have the same issue check the choke. Or you can open the drain for the float bowl, the bike I repaired had this... let it drain till it stops... with the drain still open pull a suck on the vacuum hose to see if you get the carb to drain again. I am sure it will. Then drain the carb again... hook the hose up as it should be for running... hit the started and see how long it takes to get the fuel to drain. It will take a little to drain as there is a lot of distance for it to travel.. So hit the starter for a bit and wait for the fuel.
I hope this helps to trouble shoot it.
  Vacuum petcock on scooter, how long should it hold pressure?Topic by: Stephen Keller Stephen Keller 09/07/20 11:07PM
  Re: Vacuum petcock on scooter, how long should it hold pressure?Re: Mark Booth Mark Booth 09/07/20 11:28PM
  Re: Vacuum petcock on scooter, how long should it hold pressure?Re: Stephen Keller Stephen Keller 09/07/20 11:36PM
  Re: Vacuum petcock on scooter, how long should it hold pressure?Re: Mark Booth Mark Booth 09/07/20 11:46PM
  Re: Vacuum petcock on scooter, how long should it hold pressure?Re: Stephen Keller Stephen Keller 09/07/20 11:55PM
  Re: Vacuum petcock on scooter, how long should it hold pressure?Re: Stephen Keller Stephen Keller 09/07/20 11:58PM
  Re: Vacuum petcock on scooter, how long should it hold pressure?Re: Mark Booth Mark Booth 09/08/20 12:12AM
  Re: Vacuum petcock on scooter, how long should it hold pressure?Re: Stephen Keller Stephen Keller 09/08/20 12:30AM
  Re: Vacuum petcock on scooter, how long should it hold pressure?Re: Mark Booth Mark Booth 09/08/20 12:16AM
  Re: Vacuum petcock on scooter, how long should it hold pressure?Re: Thomas TPRF Thomas TPRF 09/08/20 12:41AM
  Re: Vacuum petcock on scooter, how long should it hold pressure?Re: Stephen Keller Stephen Keller 09/08/20 12:52AM
  Re: Vacuum petcock on scooter, how long should it hold pressure?Re: Pops Peds Pops Peds 09/08/20 09:21AM
  Re: Vacuum petcock on scooter, how long should it hold pressure?Re: Stephen Keller Stephen Keller 09/08/20 11:05AM
  Re: Vacuum petcock on scooter, how long should it hold pressure?Re: Thomas TPRF Thomas TPRF 09/09/20 11:47AM
  Re: Vacuum petcock on scooter, how long should it hold pressure?Re: Stephen Keller Stephen Keller 09/09/20 12:46PM
  Re: Vacuum petcock on scooter, how long should it hold pressure?Re: Pops Peds Pops Peds 09/09/20 05:12PM
  Re: Vacuum petcock on scooter, how long should it hold pressure?Re: Graham Motzing Graham Motzing 09/09/20 01:42PM
  Re: Vacuum petcock on scooter, how long should it hold pressure?Re: Born to be WillD Born to be WillD 09/10/20 09:58AM
  Re: Vacuum petcock on scooter, how long should it hold pressure?Re: Stephen Keller Stephen Keller 09/10/20 11:10AM
  Re: Vacuum petcock on scooter, how long should it hold pressure?Re: Pops Peds Pops Peds 09/10/20 11:25AM
  Re: Vacuum petcock on scooter, how long should it hold pressure?Re: Stephen Keller Stephen Keller 09/10/20 11:33AM
  Re: Vacuum petcock on scooter, how long should it hold pressure?Re: Born to be WillD Born to be WillD 09/14/20 11:04PM
  Re: Vacuum petcock on scooter, how long should it hold pressure?Re: Stephen Keller Stephen Keller 09/15/20 12:08AM
  Re: Vacuum petcock on scooter, how long should it hold pressure?Re: Thomas TPRF Thomas TPRF 09/15/20 10:10AM
  Re: Vacuum petcock on scooter, how long should it hold pressure?Re: Pops Peds Pops Peds 09/15/20 09:22AM
  Re: Vacuum petcock on scooter, how long should it hold pressure?Re: Stephen Keller Stephen Keller 09/15/20 10:25AM
  Re: Vacuum petcock on scooter, how long should it hold pressure?Re: live ɘvil live ɘvil 09/15/20 05:37PM
  Re: Vacuum petcock on scooter, how long should it hold pressure?Re: Pops Peds Pops Peds 09/15/20 06:29PM
  Re: Vacuum petcock on scooter, how long should it hold pressure?Re: Stephen Keller Stephen Keller 09/16/20 12:48PM
