Re: Project wood fired pool heater
Satan 666 /
> Stephen Keller Wrote:
> Should work, depending on the size of the pool I guess, coupled with the
> time it takes to get the fire hot, and the potential for being downwind
> from the smoke? I would go with a homemade on demand gas burner, but
> maybe you aren't hooked up to nat gas? Even a LP fired unit, faster
> cleaner, just my 2 cents, hope it works, post pics as it progresses!
Pool is only 4' x 12 or mabye 14? It's one of those cheap metal frame pools. We got a nice way oversized pump with sand filter and the thing stays super clean. We take it down in the fall and put it back up in the spring. We dont have natural gas here but do have propane. We only use it for heat in the winter and that is to fire a rinnai heater as our only source of heat. My shop is fired by k1 as is my greenhouse but that is on an as needed basis. Dont heat the greenhouse all winter, only for wreath making season and now for seed season, and the shop is heated by a miller trailer furnace that I turn on when i go to use it. Shop is only 24x24 so the 80k hot air furnace heats her up to 55 in 25 minutes or so on 0 degree days. Burn around 5 or so gallons a week in the winter months. The pool is another hobby so we will work to try and keep it warm. Dont want to add to our heat bill and have a ton of downed trees on the property that need cleaning up so I will cut and split I guess. I have a gas wood splitter but I just purchased an electric splitter that will work great for all the pine and my wife can use it no problem. The gas job is good for big stuff and can be a little intimidating for her. Went for a walk the other day and have at least 4 or 5 cords of blow downs I can get with my wheeler and trailer. Maine life is kinda like this. I enjoy the struggle and hard work to get things done. The company I work for slows down in the winter and we harvest oak from my bosses property and mostly hand split 20 cord to fit in this shed. It is four layers deep. Maine is a cool place. Life slows down in the cold months and then we work hard to try and relax in the warm months so this heater will help I hope.
  Project wood fired pool heaterTopic by: Satan 666 Satan 666 05/01/20 06:38PM
  Re: Project wood fired pool heaterRe: Satan 666 Satan 666 05/01/20 06:47PM
  Re: Project wood fired pool heaterRe: ID OD ID OD 05/01/20 06:49PM
  Re: Project wood fired pool heaterRe: Stephen Keller Stephen Keller 05/01/20 06:54PM
  Re: Project wood fired pool heaterRe: Satan 666 Satan 666 05/01/20 11:38PM
  Re: Project wood fired pool heaterRe: Bas Autowas Bas Autowas 05/01/20 07:46PM
  Re: Project wood fired pool heaterRe: Pushrod Fifty Pushrod Fifty 05/01/20 08:40PM
  Re: Project wood fired pool heaterRe: Satan 666 Satan 666 05/01/20 11:47PM
  Re: Project wood fired pool heaterRe: Seth B Seth B 05/03/20 12:56AM
  Re: Project wood fired pool heaterRe: Satan 666 Satan 666 05/03/20 08:02AM
  Re: Project wood fired pool heaterRe: Stephen Keller Stephen Keller 05/03/20 03:25PM
  Re: Project wood fired pool heaterRe: Jared Rut Jared Rut 05/22/20 08:04AM
  Re: Project wood fired pool heaterRe: live ɘvil live ɘvil 05/23/20 11:16AM
  Re: Project wood fired pool heaterRe: Seth B Seth B 05/24/20 12:32AM
  Re: Project wood fired pool heaterRe: Satan 666 Satan 666 05/24/20 10:03PM
  Re: Project wood fired pool heaterRe: Jared Rut Jared Rut 05/25/20 07:12PM
  Re: Project wood fired pool heaterRe: Satan 666 Satan 666 05/26/20 07:08AM
  Re: Project wood fired pool heaterRe: Satan 666 Satan 666 05/31/20 12:47PM
  Re: Project wood fired pool heaterRe: live ɘvil live ɘvil 05/31/20 01:36PM
  Re: Project wood fired pool heaterRe: Satan 666 Satan 666 05/31/20 12:48PM
  Re: Project wood fired pool heaterRe: Satan 666 Satan 666 05/31/20 03:23PM
  Re: Project wood fired pool heaterRe: live ɘvil live ɘvil 06/01/20 07:36PM
  Re: Project wood fired pool heaterRe: Ryan Graeme Ryan Graeme 06/02/20 12:00AM
  Re: Project wood fired pool heaterRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 06/13/20 12:48PM
  Re: Project wood fired pool heaterRe: Satan 666 Satan 666 06/02/20 08:51PM
  Re: Project wood fired pool heaterRe: live ɘvil live ɘvil 06/05/20 06:55PM
  Re: Project wood fired pool heaterRe: up shits creek up shits creek 06/10/20 10:16PM
  Re: Project wood fired pool heaterRe: punkrock randy punkrock randy 06/13/20 12:26PM
  Re: Project wood fired pool heaterRe: Bas Autowas Bas Autowas 06/13/20 01:16PM
  Re: Project wood fired pool heaterRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 06/13/20 01:47PM
  Re: Project wood fired pool heaterRe: Bas Autowas Bas Autowas 06/13/20 02:07PM
