Re: How is everyone spending their days?
52 bolts holds all of the components in place. 15 o-rings sandwiched between the inner cover and the front of the block to seal in the oil. 3 of them are pressurized oil.
The 4cyl Subaru water pumps are driven by the t-belt, but they’re a walk in the park compared to this dumb shit. We replace a lot of head gaskets on them for oil leaks too.
And if your Audi needs extensive amounts of cash to repair, you deserve it.
Tech tip of the day: How not to brake wheel studs.
Have you ever put a lug nut back on and it started getting tight before it even made contact with the wheel? Then it won’t come back off, or destroys the threads if it does. WTF? It came off just fine the first time.
Whenever a lug nut is removed, hold it open end down and tap it on a firm surface a few times to remove the tiny metal chips. The metal dust collects inside the nut and will eventually destroy the threads. After years of rotations, inspections, and brake repairs, the threads naturally wear a little. Clearing the metal dust from the nuts will help them to llast the life of the vehicle.
DO NOT apply anti-seize, to anything. Ever. It gets all over my hands and your interior before i notice what the fuck you did. Plus it holds these thread-eating little chips inside the nut so they can continue to ruin your studs. if you own a jar of this junk, throw it away. The 1960’s are over.
Don’t get me wrong, there is a place and time for lubed studs. A lot of the older vehicles did not use acorn style nuts and the threads are exposed to the elements. This would be a good place for a silicone lubricant. However over time, if the nuts start to feel sticky, the lube is loading up with chips and it’s time to clean them and re-lubricate.
I also use lube after restoring to chewed up stud that had “dust” damage. Grind away the ugly threads and touch up the others with a triangle file. You don’t need all of them. Just most. ;)
Some steel wheel GM engineer decided to make the stud holes in the wheel too small, so when the nuts are torqued down, the tapered part of the nut gets crushed smaller. The nuts then come off hard, and can be impossible to thread back on. Removing the first thread or 2 from inside the nut with a tapered die grinder bit will cure the issue.
Enough of this shit for today. I’m going home to play.
(edited)
  How is everyone spending their days?Topic by: kenny s kenny s 03/14/20 08:37PM
  Re: How is everyone spending their days?Re: Brandon Love Brandon Love 03/14/20 08:39PM
  Re: How is everyone spending their days?Re: A Zed A Zed 03/15/20 03:08PM
  Re: How is everyone spending their days?Re: Seth B Seth B 03/14/20 09:17PM
  Re: How is everyone spending their days?Re: Stephen Keller Stephen Keller 03/15/20 12:06AM
  Re: How is everyone spending their days?Re: Seth B Seth B 03/15/20 12:58AM
  Re: How is everyone spending their days?Re: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 03/14/20 09:28PM
  Re: How is everyone spending their days?Re: Don Ohio Don Ohio 03/14/20 11:33PM
  Re: How is everyone spending their days?Re: Stephen Keller Stephen Keller 03/14/20 11:58PM
  Re: How is everyone spending their days?Re: Stephen Keller Stephen Keller 03/14/20 11:56PM
  Re: How is everyone spending their days?Re: Brandon Love Brandon Love 03/15/20 12:57AM
  Re: How is everyone spending their days?Re: Stephen Keller Stephen Keller 03/15/20 02:56AM
  Re: How is everyone spending their days?Re: A Zed A Zed 03/15/20 03:14PM
  Re: How is everyone spending their days?Re: Pushrod Fifty Pushrod Fifty 03/15/20 08:55AM
  Re: How is everyone spending their days?Re: Don Ohio Don Ohio 03/15/20 05:26PM
  Re: How is everyone spending their days?Re: Stephen Keller Stephen Keller 03/15/20 10:31PM
  Re: How is everyone spending their days?Re: Saabsonettguy . Saabsonettguy . 03/15/20 09:52AM
  Re: How is everyone spending their days?Re: Moped Lar (OFMC) Moped Lar (OFMC) 03/15/20 11:35AM
  Re: How is everyone spending their days?Re: punkrock randy punkrock randy 03/15/20 01:16PM
  Re: How is everyone spending their days?Re: Bas Autowas Bas Autowas 03/15/20 01:22PM
  Re: How is everyone spending their days?Re: Stephen Keller Stephen Keller 03/15/20 03:28PM
  Re: How is everyone spending their days?Re: Bas Autowas Bas Autowas 03/15/20 03:41PM
  Re: How is everyone spending their days?Re: Stephen Keller Stephen Keller 03/15/20 03:44PM
  Re: How is everyone spending their days?Re: Bas Autowas Bas Autowas 03/16/20 01:12PM
  Re: How is everyone spending their days?Re: . chillywillie . chillywillie 03/15/20 05:20PM
  Re: How is everyone spending their days?Re: Jeff Parr Jeff Parr 03/15/20 01:23PM
  Re: How is everyone spending their days?Re: Stephen Keller Stephen Keller 03/15/20 04:44PM
  Re: How is everyone spending their days?Re: Pushrod Fifty Pushrod Fifty 03/15/20 05:55PM
  Re: How is everyone spending their days?Re: Jimmy Cincinnati Jimmy Cincinnati 03/15/20 06:28PM
  Re: How is everyone spending their days?Re: Bas Autowas Bas Autowas 03/15/20 07:23PM
  Re: How is everyone spending their days?Re: Chris . Chris . 03/15/20 07:58PM
  Re: How is everyone spending their days?Re: Bas Autowas Bas Autowas 03/15/20 08:05PM
  Re: How is everyone spending their days?Re: live ɘvil live ɘvil 03/16/20 04:06AM
  Re: How is everyone spending their days?Re: Ryan Graeme Ryan Graeme 03/16/20 07:22PM
  Re: How is everyone spending their days?Re: Born to be WillD Born to be WillD 03/16/20 12:56PM
  Re: How is everyone spending their days?Re: Graham Motzing Graham Motzing 03/16/20 01:25PM
  Re: How is everyone spending their days?Re: Pops Peds Pops Peds 03/16/20 01:30PM
  Re: How is everyone spending their days?Re: Overpriced Parts Overpriced Parts 03/16/20 04:52PM
  Re: How is everyone spending their days?Re: Pops Peds Pops Peds 03/16/20 04:56PM
  Re: How is everyone spending their days?Re: Overpriced Parts Overpriced Parts 03/16/20 05:41PM
  Re: How is everyone spending their days?Re: live ɘvil live ɘvil 03/16/20 07:25PM
  Re: How is everyone spending their days?Re: Stephen Keller Stephen Keller 03/16/20 07:11PM
  Re: How is everyone spending their days?Re: Rick Bergsma Rick Bergsma 03/18/20 08:14AM
  Re: How is everyone spending their days?Re: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 03/18/20 11:56AM
  Re: How is everyone spending their days?Re: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 03/18/20 12:08PM
  Re: How is everyone spending their days?Re: Brad William Brad William 03/18/20 12:31PM
  Re: How is everyone spending their days?Re: Stephen Keller Stephen Keller 03/18/20 01:25PM
  Re: How is everyone spending their days?Re: Mild Mods Mild Mods 03/18/20 02:23PM
  Re: How is everyone spending their days?Re: Stephen Keller Stephen Keller 03/18/20 03:19PM
  Re: How is everyone spending their days?Re: Mild Mods Mild Mods 03/18/20 01:27PM
  Re: How is everyone spending their days?Re: Stephen Keller Stephen Keller 03/18/20 01:45PM
  Re: How is everyone spending their days?Re: Graham Motzing Graham Motzing 03/18/20 02:27PM
  Re: How is everyone spending their days?Re: Don Ohio Don Ohio 03/16/20 09:43PM
  Re: How is everyone spending their days?Re: Satan 666 Satan 666 03/17/20 06:44AM
  Re: How is everyone spending their days?Re: Stephen Keller Stephen Keller 03/17/20 01:33PM
  Re: How is everyone spending their days?Re: Moped Lar (OFMC) Moped Lar (OFMC) 03/17/20 01:44PM
  Re: How is everyone spending their days?Re: Stephen Keller Stephen Keller 03/17/20 01:55PM
  Re: How is everyone spending their days?Re: Jeff Parr Jeff Parr 03/17/20 02:50PM
  Re: How is everyone spending their days?Re: Bas Autowas Bas Autowas 03/17/20 02:56PM
  Re: How is everyone spending their days?Re: Jeff Parr Jeff Parr 03/17/20 09:53AM
  Re: How is everyone spending their days?Re: Don Ohio Don Ohio 03/18/20 12:21PM
  Re: How is everyone spending their days?Re: Mild Mods Mild Mods 03/18/20 02:24PM
  Re: How is everyone spending their days?Re: punkrock randy punkrock randy 03/18/20 03:10PM
  Re: How is everyone spending their days?Re: Mild Mods Mild Mods 03/18/20 04:17PM
  Re: How is everyone spending their days?Re: Stephen Keller Stephen Keller 03/18/20 07:10PM
  Re: How is everyone spending their days?Re: jayson sumpter jayson sumpter 03/20/20 10:45AM
  Re: How is everyone spending their days?Re: Rebel Moby Rebel Moby 03/18/20 05:15PM
  Re: How is everyone spending their days?Re: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 03/18/20 06:12PM
  Re: How is everyone spending their days?Re: live ɘvil live ɘvil 03/18/20 06:44PM
  Re: How is everyone spending their days?Re: live ɘvil live ɘvil 03/18/20 06:50PM
  Re: How is everyone spending their days?Re: kenny s kenny s 03/18/20 09:09PM
  Re: How is everyone spending their days?Re: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 03/19/20 09:23AM
  Re: How is everyone spending their days?Re: Pops Peds Pops Peds 03/19/20 09:54AM
  Re: How is everyone spending their days?Re: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 03/19/20 10:08AM
  Re: How is everyone spending their days?Re: Pops Peds Pops Peds 03/19/20 10:25AM
  Re: How is everyone spending their days?Re: Stephen Keller Stephen Keller 03/19/20 12:56PM
  Re: How is everyone spending their days?Re: Graham Motzing Graham Motzing 03/18/20 09:46PM
  Re: How is everyone spending their days?Re: live ɘvil live ɘvil 03/18/20 10:23PM
  Re: How is everyone spending their days?Re: Overpriced Parts Overpriced Parts 03/18/20 06:50PM
  Re: How is everyone spending their days?Re: P8R . P8R . 03/18/20 09:35PM
  Re: How is everyone spending their days?Re: Don Ohio Don Ohio 03/18/20 11:03PM
  Re: How is everyone spending their days?Re: Brandon Love Brandon Love 03/19/20 02:43AM
  Re: How is everyone spending their days?Re: Pops Peds Pops Peds 03/19/20 06:06AM
  Re: How is everyone spending their days?Re: Don Ohio Don Ohio 03/19/20 10:12AM
  Re: How is everyone spending their days?Re: punkrock randy punkrock randy 03/19/20 01:11PM
  Re: How is everyone spending their days?Re: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 03/19/20 05:31PM
  Re: How is everyone spending their days?Re: ID OD ID OD 03/19/20 06:59PM
  Re: How is everyone spending their days?Re: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 03/19/20 10:33PM
  Re: How is everyone spending their days?Re: Satan 666 Satan 666 03/19/20 09:14PM
  Re: How is everyone spending their days?Re: Satan 666 Satan 666 03/19/20 09:18PM
  Re: How is everyone spending their days?Re: live ɘvil live ɘvil 03/19/20 09:23PM
  Re: How is everyone spending their days?Re: Satan 666 Satan 666 03/19/20 09:25PM
  Re: How is everyone spending their days?Re: Offical Kyle™ Offical Kyle™ 03/20/20 03:56AM
  Re: How is everyone spending their days?Re: Don Ohio Don Ohio 03/20/20 10:31AM
  Re: How is everyone spending their days?Re: Moped Lar (OFMC) Moped Lar (OFMC) 03/20/20 10:36AM
  Re: How is everyone spending their days?Re: Jimmy Cincinnati Jimmy Cincinnati 03/20/20 11:44AM
  Re: How is everyone spending their days?Re: Don Ohio Don Ohio 03/20/20 12:56PM
  Re: How is everyone spending their days?Re: Don Ohio Don Ohio 03/21/20 12:19AM
  Re: How is everyone spending their days?Re: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 03/21/20 04:27AM
  Re: How is everyone spending their days?Re: jayson sumpter jayson sumpter 03/21/20 08:08AM
  Re: How is everyone spending their days?Re: Don Ohio Don Ohio 03/21/20 10:28AM
  Re: How is everyone spending their days?Re: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 03/21/20 11:35AM
  Re: How is everyone spending their days?Re: live ɘvil live ɘvil 03/23/20 04:02AM
  Re: How is everyone spending their days?Re: Bas Autowas Bas Autowas 03/23/20 11:49AM
  Re: How is everyone spending their days?Re: kenny s kenny s 03/23/20 12:06PM
  Re: How is everyone spending their days?Re: Bas Autowas Bas Autowas 03/23/20 01:17PM
  Re: How is everyone spending their days?Re: A Zed A Zed 03/23/20 06:31PM
  Re: How is everyone spending their days?Re: Stephen Keller Stephen Keller 03/21/20 11:55AM
  Re: How is everyone spending their days?Re: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 03/21/20 12:25PM
  Re: How is everyone spending their days?Re: Seth B Seth B 03/21/20 01:14PM
  Re: How is everyone spending their days?Re: Brandon Love Brandon Love 03/21/20 01:06AM
  Re: How is everyone spending their days?Re: Jimmy Cincinnati Jimmy Cincinnati 03/23/20 01:41PM
  Re: How is everyone spending their days?Re: Bas Autowas Bas Autowas 03/23/20 02:13PM
  Re: How is everyone spending their days?Re: ID OD ID OD 03/23/20 02:18PM
  Re: How is everyone spending their days?Re: Jimmy Cincinnati Jimmy Cincinnati 03/23/20 06:03PM
  Re: How is everyone spending their days?Re: ID OD ID OD 03/23/20 06:24PM
  Re: How is everyone spending their days?Re: Ryan Graeme Ryan Graeme 03/23/20 06:30PM
  Re: How is everyone spending their days?Re: Don Ohio Don Ohio 03/23/20 06:27PM
  Re: How is everyone spending their days?Re: live ɘvil live ɘvil 03/23/20 07:04PM
  Re: How is everyone spending their days?Re: Jimmy Cincinnati Jimmy Cincinnati 03/23/20 07:56PM
  Re: How is everyone spending their days?Re: Don Ohio Don Ohio 03/23/20 11:53PM
  Re: How is everyone spending their days?Re: Ryan Graeme Ryan Graeme 03/24/20 04:38AM
  Re: How is everyone spending their days?Re: punkrock randy punkrock randy 03/24/20 09:35AM
  Re: How is everyone spending their days?Re: live ɘvil live ɘvil 03/24/20 10:08AM
  Re: How is everyone spending their days?Re: Bas Autowas Bas Autowas 03/24/20 10:11AM
  Re: How is everyone spending their days?Re: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 03/26/20 08:51AM
  Re: How is everyone spending their days?Re: live ɘvil live ɘvil 03/27/20 08:12PM
  Re: How is everyone spending their days?Re: Dr No Fun Dr No Fun 03/27/20 08:47PM
  Re: How is everyone spending their days?Re: live ɘvil live ɘvil 03/28/20 08:47PM
  Re: How is everyone spending their days?Re: Bas Autowas Bas Autowas 03/30/20 10:33AM
  Re: How is everyone spending their days?Re: Stephen Keller Stephen Keller 03/30/20 12:57PM
  Re: How is everyone spending their days?Re: punkrock randy punkrock randy 03/24/20 10:16AM
  Re: How is everyone spending their days?Re: Don Ohio Don Ohio 03/24/20 11:31AM
  Re: How is everyone spending their days?Re: Bas Autowas Bas Autowas 03/24/20 11:51AM
  Re: How is everyone spending their days?Re: Jimmy Cincinnati Jimmy Cincinnati 03/24/20 12:55PM
  Re: How is everyone spending their days?Re: Bas Autowas Bas Autowas 03/24/20 01:12PM
  Re: How is everyone spending their days?Re: punkrock randy punkrock randy 03/26/20 08:44AM
  Re: How is everyone spending their days?Re: __̴ı̴̴̡̡̡ ̡͌l̡̡̡ ̡͌l̡*̡̡ ̴̡ı̴̴̡ ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡͡ ̲|̡̡̡ ̡ ̴̡ı̴̡̡ ̡͌l̡̡̡̡.__ __̴ı̴̴̡̡̡ ̡͌l̡̡̡ ̡͌l̡*̡̡ ̴̡ı̴̴̡ ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡͡ ̲|̡̡̡ ̡ ̴̡ı̴̡̡ ̡͌l̡̡̡̡.__ 03/30/20 02:35PM
