Re: Two stroke oil in your car's fuel tank??
Chris Szuba /
so, as a rotary owner i can dabble on that bit. you pre mix if you delete you OMP or oil metering pump. this was a rod that connected to your throttle body and would pump oil into the TB from the pan!! this would make rotaries require more frequent oil changes. Mazda did this bc they couldnt sell the car as "hey small side note, you need to pour oil in your tank whenever you fill up. gucci? cool"
yeah naw, people wouldnt wanna do that or forget/neglect and BOOM goes rotary.
us gear heads however dont want gross oil pan oil being used to lubricate the apex seals in the engine so we delete the OMP/rod/lines and switch to premixing.
Also when the OMP would fail there would be no signs, your engine would just seize lol
rotaries are CAR PEOPLE cars. they're really cool and very simple once you understand them. with the OMP still hooked up you can pre mix 1/2 oz per gal in your tank. if you delete it, you should run 1oz per gal in your tank. idr what the ratio's are
  Two stroke oil in your car's fuel tank??Topic by: Angry Hipster Angry Hipster 10/30/19 04:36PM
  Re: Two stroke oil in your car's fuel tank??Re: Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F 10/30/19 04:54PM
  Re: Two stroke oil in your car's fuel tank??Re: Probably Fred Probably Fred 10/30/19 05:41PM
  Re: Two stroke oil in your car's fuel tank??Re: Stephen Keller Stephen Keller 10/30/19 07:04PM
  Re: Two stroke oil in your car's fuel tank??Re: Thomas TPRF Thomas TPRF 10/30/19 07:45PM
  Re: Two stroke oil in your car's fuel tank??Re: Josiah Radebaugh Josiah Radebaugh 10/30/19 08:34PM
  Re: Two stroke oil in your car's fuel tank??Re: Born to be WillD Born to be WillD 10/30/19 11:25PM
  Re: Two stroke oil in your car's fuel tank??Re: Don Ohio Don Ohio 10/31/19 12:52AM
  Re: Two stroke oil in your car's fuel tank??Re: ♣Slew Foot♣ ♣Slew Foot♣ 10/31/19 04:30AM
  Re: Two stroke oil in your car's fuel tank??Re: live ɘvil live ɘvil 10/31/19 06:04AM
  Re: Two stroke oil in your car's fuel tank??Re: Rebel Moby Rebel Moby 10/31/19 03:51PM
  Re: Two stroke oil in your car's fuel tank??Re: Angry Hipster Angry Hipster 10/31/19 04:17PM
  Re: Two stroke oil in your car's fuel tank??Re: Chris Szuba Chris Szuba 11/01/19 06:32AM
  Re: Two stroke oil in your car's fuel tank??Re: Josiah Radebaugh Josiah Radebaugh 11/01/19 10:13AM
  Re: Two stroke oil in your car's fuel tank??Re: Chris Szuba Chris Szuba 11/04/19 07:54AM
  Re: Two stroke oil in your car's fuel tank??Re: Fred Braue Fred Braue 11/01/19 10:26AM
