Re: New cars are shit
Yes Stephen. Somewhere along the way someone used an AMC donor car for the engine, trans, rear, steering column and wheel, and the heater box assembly. The heater box had a thru-firewall blower motor similar to the original, but at a different location, so they cut a huge hole in the firewall. I sourced an original heater box to replace it. The clock face was the only thing large enough in my scrap bin at the time to cover the entire hole.
I replaced the shit AMC column with a 58 Fairlane column with a Ford-o-matic column shifter and a 53 Truck steering wheel so it looks original, and a mid 80’s Toyota truck power steering gear box for some much needed power steering.
The guy I bought it from installed the 283/powerglide and 3.70 9” rear. The 283 is 65-66 era according to the carb tag. Notice the “no pcv” valve covers. Just a draft tube to the road. And a fucking rag for an oil cap, piece of shit truck. Lol
Early 80’s lincoln master cylinder, Chrysler radiator. GM “1 wire” alterator. The entire engine wiring harness will fit in your pocket. I re-wired the harness to the rear lights with several feet of an old heavy duty black rubber 12-2 w/ground extension cord. No backup lights, no windshield washers, no 4 way flashers. All options in its day.
61-66 f series 9” rear bolts right under the 53-56 trucks. I think he put the high back Camaro seats in it on a square tubing nightmare of a frame. Floor shifter was close to the floor and you had to reach back towards the back of the cab. Dumb. High back seats don’t work in these trucks, so i put an original bench back in and made linkage for the column shifter.
I slammed the front by removing all but three plys from each front leaf spring. Original spring stacks in rear with overload ply stacks on top. New spring pins and bushings on all 4 corners. New kin pins and bushings. Added a FAT swaybar to the front and a “solid” bar tierod. Added the wheels and 255/70/15 BFG/TA’s.
Rides nicer than a mustang GT, accelerates faster than your Yarus, it’ll haul over a ton and a half of scrap steel with ease, and it handles way better than a Grayhound bus. Still rockin’ 11” drums on all 4 corners. I can easily lock all 4 at any speed. The sound is more effective than any horn ever made. Screeching hollering tires always turns heads. ;)(edited)
  New cars are shitTopic by: Angry Hipster Angry Hipster 03/30/19 05:36PM
  Re: New cars are shitRe: Chöschi21 C.K. Chöschi21 C.K. 03/30/19 06:02PM
  Re: New cars are shitRe: Daniel '' Daniel '' 03/30/19 06:13PM
  Re: New cars are shitRe: Blake MD No PM Plz Blake MD No PM Plz 03/30/19 06:20PM
  Re: New cars are shitRe: Thomas Smith Thomas Smith 03/30/19 06:33PM
  Re: New cars are shitRe: Jeff Parr Jeff Parr 03/30/19 07:40PM
  Re: New cars are shitRe: Stephen Keller Stephen Keller 03/30/19 08:00PM
  Re: New cars are shitRe: Born to be WillD Born to be WillD 03/30/19 08:08PM
  Re: New cars are shitRe: Stephen Keller Stephen Keller 03/30/19 08:19PM
  Re: New cars are shitRe: __̴ı̴̴̡̡̡ ̡͌l̡̡̡ ̡͌l̡*̡̡ ̴̡ı̴̴̡ ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡͡ ̲|̡̡̡ ̡ ̴̡ı̴̡̡ ̡͌l̡̡̡̡.__ __̴ı̴̴̡̡̡ ̡͌l̡̡̡ ̡͌l̡*̡̡ ̴̡ı̴̴̡ ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡͡ ̲|̡̡̡ ̡ ̴̡ı̴̡̡ ̡͌l̡̡̡̡.__ 03/30/19 08:14PM
  Re: New cars are shitRe: Born to be WillD Born to be WillD 04/03/19 04:15PM
  Re: New cars are shitRe: Stephen Keller Stephen Keller 04/03/19 07:09PM
  Re: New cars are shitRe: Don Ohio Don Ohio 03/30/19 10:27PM
  Re: New cars are shitRe: __̴ı̴̴̡̡̡ ̡͌l̡̡̡ ̡͌l̡*̡̡ ̴̡ı̴̴̡ ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡͡ ̲|̡̡̡ ̡ ̴̡ı̴̡̡ ̡͌l̡̡̡̡.__ __̴ı̴̴̡̡̡ ̡͌l̡̡̡ ̡͌l̡*̡̡ ̴̡ı̴̴̡ ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡͡ ̲|̡̡̡ ̡ ̴̡ı̴̡̡ ̡͌l̡̡̡̡.__ 03/30/19 10:40PM
  Re: New cars are shitRe: Don Ohio Don Ohio 03/30/19 11:17PM
  Re: New cars are shitRe: Paola De Leon Paola De Leon 04/15/19 12:17AM
  Re: New cars are shitRe: Don Ohio Don Ohio 03/31/19 12:15AM
  Re: New cars are shitRe: __̴ı̴̴̡̡̡ ̡͌l̡̡̡ ̡͌l̡*̡̡ ̴̡ı̴̴̡ ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡͡ ̲|̡̡̡ ̡ ̴̡ı̴̡̡ ̡͌l̡̡̡̡.__ __̴ı̴̴̡̡̡ ̡͌l̡̡̡ ̡͌l̡*̡̡ ̴̡ı̴̴̡ ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡͡ ̲|̡̡̡ ̡ ̴̡ı̴̡̡ ̡͌l̡̡̡̡.__ 03/31/19 01:00AM
  Re: New cars are shitRe: Brad William Brad William 03/31/19 02:23PM
  Re: New cars are shitRe: kenny s kenny s 03/31/19 02:32PM
  Re: New cars are shitRe: Brad William Brad William 03/31/19 02:43PM
  Re: New cars are shitRe: Don Ohio Don Ohio 03/31/19 02:45PM
  Re: New cars are shitRe: kevin Smellaflange kevin Smellaflange 03/31/19 02:58PM
  Re: New cars are shitRe: Thomas TPRF Thomas TPRF 04/02/19 04:03PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 03/31/19 04:26PM
  Re: New cars are shitRe: Overpriced Parts Overpriced Parts 03/31/19 05:29PM
  Re: New cars are shitRe: Jarod V. Jarod V. 04/09/19 05:39PM
  Re: New cars are shitRe: Don Ohio Don Ohio 03/31/19 04:42PM
  Re: New cars are shitRe: Paola De Leon Paola De Leon 04/14/19 10:20PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 03/31/19 06:08PM
  Re: New cars are shitRe: Overpriced Parts Overpriced Parts 04/02/19 04:22PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/02/19 05:17PM
  Re: New cars are shitRe: Thomas TPRF Thomas TPRF 04/03/19 09:47AM
  Re: New cars are shitRe: Born to be WillD Born to be WillD 04/04/19 01:42PM
  Re: New cars are shitRe: Moped Lar (OFMC) Moped Lar (OFMC) 04/03/19 09:47AM
  Re: New cars are shitRe: Andrew Squiggman Andrew Squiggman 04/03/19 10:53AM
  Re: New cars are shitRe: Thomas TPRF Thomas TPRF 04/05/19 09:15AM
  Re: New cars are shitRe: Stephen Keller Stephen Keller 04/05/19 01:53PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/05/19 01:58PM
  Re: New cars are shitRe: Stephen Keller Stephen Keller 04/05/19 02:00PM
  Re: New cars are shitRe: Paola De Leon Paola De Leon 04/14/19 11:42PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/15/19 12:10AM
  Re: New cars are shitRe: __̴ı̴̴̡̡̡ ̡͌l̡̡̡ ̡͌l̡*̡̡ ̴̡ı̴̴̡ ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡͡ ̲|̡̡̡ ̡ ̴̡ı̴̡̡ ̡͌l̡̡̡̡.__ __̴ı̴̴̡̡̡ ̡͌l̡̡̡ ̡͌l̡*̡̡ ̴̡ı̴̴̡ ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡͡ ̲|̡̡̡ ̡ ̴̡ı̴̡̡ ̡͌l̡̡̡̡.__ 03/31/19 06:30PM
  Re: New cars are shitRe: Chris Szuba Chris Szuba 04/02/19 07:40AM
  Re: New cars are shitRe: I M I M 04/03/19 09:15AM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/15/19 12:06AM
  Re: New cars are shitRe: I M I M 04/25/19 07:01AM
  Re: New cars are shitRe: kevin Smellaflange kevin Smellaflange 04/25/19 08:13AM
  Re: New cars are shitRe: Jeff Parr Jeff Parr 04/03/19 11:08AM
  Re: New cars are shitRe: Moped Lar (OFMC) Moped Lar (OFMC) 04/03/19 11:19AM
  Re: New cars are shitRe: Jimmy Cincinnati Jimmy Cincinnati 04/03/19 11:12AM
  Re: New cars are shitRe: jayson sumpter jayson sumpter 04/03/19 11:28AM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/03/19 04:53PM
  Re: New cars are shitRe: Andrew Squiggman Andrew Squiggman 04/03/19 04:55PM
  Re: New cars are shitRe: Jeff Parr Jeff Parr 04/03/19 04:58PM
  Re: New cars are shitRe: Jimmy Cincinnati Jimmy Cincinnati 04/03/19 09:37PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/04/19 08:45AM
  Re: New cars are shitRe: informatique formation informatique formation 04/04/19 04:56PM
  Re: New cars are shitRe: Born to be WillD Born to be WillD 04/08/19 11:51AM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/08/19 12:20PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/08/19 06:33PM
  Re: New cars are shitRe: Born to be WillD Born to be WillD 04/16/19 10:20AM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/16/19 10:51AM
  Re: New cars are shitRe: Andrew Squiggman Andrew Squiggman 04/17/19 12:04AM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/17/19 12:10AM
  Re: New cars are shitRe: Paola De Leon Paola De Leon 04/17/19 01:08AM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/17/19 01:17AM
  Re: New cars are shitRe: Paola De Leon Paola De Leon 04/17/19 01:42AM
  Re: New cars are shitRe: Daniel '' Daniel '' 04/17/19 12:52PM
  Re: New cars are shitRe: kevin Smellaflange kevin Smellaflange 04/04/19 07:51PM
  Re: New cars are shitRe: Stephen Keller Stephen Keller 04/04/19 10:13PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/05/19 09:51AM
  Re: New cars are shitRe: Thomas TPRF Thomas TPRF 04/05/19 10:00AM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/05/19 01:08PM
  Re: New cars are shitRe: Jimmy Cincinnati Jimmy Cincinnati 04/05/19 12:36PM
  Re: New cars are shitRe: Jimmy Cincinnati Jimmy Cincinnati 04/05/19 03:23PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/05/19 04:29PM
  Re: New cars are shitRe: kevin Smellaflange kevin Smellaflange 04/07/19 11:38AM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/05/19 04:41PM
  Re: New cars are shitRe: Jimmy Cincinnati Jimmy Cincinnati 04/05/19 05:21PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/05/19 06:39PM
  Re: New cars are shitRe: Stephen Keller Stephen Keller 04/05/19 07:18PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/06/19 12:02AM
  Re: New cars are shitRe: __̴ı̴̴̡̡̡ ̡͌l̡̡̡ ̡͌l̡*̡̡ ̴̡ı̴̴̡ ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡͡ ̲|̡̡̡ ̡ ̴̡ı̴̡̡ ̡͌l̡̡̡̡.__ __̴ı̴̴̡̡̡ ̡͌l̡̡̡ ̡͌l̡*̡̡ ̴̡ı̴̴̡ ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡͡ ̲|̡̡̡ ̡ ̴̡ı̴̡̡ ̡͌l̡̡̡̡.__ 04/06/19 09:13PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/07/19 05:21PM
  Re: New cars are shitRe: Jimmy Cincinnati Jimmy Cincinnati 04/08/19 12:53PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/08/19 04:09PM
  Re: New cars are shitRe: Born to be WillD Born to be WillD 04/09/19 08:54AM
  Re: New cars are shitRe: Chöschi21 C.K. Chöschi21 C.K. 04/08/19 05:04PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/08/19 06:12PM
  Re: New cars are shitRe: Chöschi21 C.K. Chöschi21 C.K. 04/10/19 06:56AM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/08/19 07:37PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/09/19 12:58AM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/09/19 09:52AM
  Re: New cars are shitRe: Born to be WillD Born to be WillD 04/10/19 10:15AM
  Re: New cars are shitRe: Thomas TPRF Thomas TPRF 04/13/19 01:22AM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/13/19 01:41AM
  Re: New cars are shitRe: Thomas TPRF Thomas TPRF 04/13/19 11:04AM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/09/19 10:08AM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/09/19 12:45PM
  Re: New cars are shitRe: Jimmy Cincinnati Jimmy Cincinnati 04/09/19 02:11PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/09/19 02:15PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/09/19 03:07PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/09/19 05:51PM
  Re: New cars are shitRe: Jarod V. Jarod V. 04/09/19 07:24PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/09/19 07:57PM
  Re: New cars are shitRe: Jarod V. Jarod V. 04/09/19 09:26PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/09/19 09:47PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/10/19 12:42AM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/14/19 04:12PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/10/19 10:26AM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/10/19 10:58AM
  Re: New cars are shitRe: Jimmy Cincinnati Jimmy Cincinnati 04/10/19 12:16PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/10/19 12:22PM
  Re: New cars are shitRe: Andrew Squiggman Andrew Squiggman 04/10/19 12:45PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/10/19 12:19PM
  Re: New cars are shitRe: Dirty30 Dillon Dirty30 Dillon 04/10/19 03:37PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/10/19 03:51PM
  Re: New cars are shitRe: Dirty30 Dillon Dirty30 Dillon 04/10/19 04:05PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/10/19 04:12PM
  Re: New cars are shitRe: Dirty30 Dillon Dirty30 Dillon 04/10/19 04:14PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/10/19 04:15PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/10/19 04:18PM
  Re: New cars are shitRe: Dirty30 Dillon Dirty30 Dillon 04/10/19 04:34PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/10/19 04:40PM
  Re: New cars are shitRe: Dirty30 Dillon Dirty30 Dillon 04/10/19 04:57PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/10/19 05:02PM
  Re: New cars are shitRe: Dirty30 Dillon Dirty30 Dillon 04/10/19 05:08PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/10/19 05:13PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/10/19 05:50PM
  Re: New cars are shitRe: Stephen Keller Stephen Keller 04/10/19 07:10PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/10/19 07:51PM
  Re: New cars are shitRe: Stephen Keller Stephen Keller 04/10/19 10:30PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/11/19 01:48AM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/10/19 09:54PM
  Re: New cars are shitRe: Jimmy Cincinnati Jimmy Cincinnati 04/11/19 07:51AM
  Re: New cars are shitRe: Born to be WillD Born to be WillD 04/11/19 09:35AM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/11/19 10:25AM
  Re: New cars are shitRe: Jimmy Cincinnati Jimmy Cincinnati 04/11/19 11:08AM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/12/19 12:56AM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/11/19 11:24AM
  Re: New cars are shitRe: P8R . P8R . 04/11/19 04:23PM
  Re: New cars are shitRe: Born to be WillD Born to be WillD 04/12/19 10:54AM
  Re: New cars are shitRe: P8R . P8R . 04/12/19 11:17AM
  Re: New cars are shitRe: Jimmy Cincinnati Jimmy Cincinnati 04/11/19 04:32PM
  Re: New cars are shitRe: Jimmy Cincinnati Jimmy Cincinnati 04/12/19 10:17AM
  Re: New cars are shitRe: Stephen Keller Stephen Keller 04/12/19 11:49AM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/13/19 01:13AM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/13/19 03:07PM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/14/19 12:54PM
  Re: New cars are shitRe: . chillywillie . chillywillie 04/14/19 01:20PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/14/19 04:23PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/14/19 08:01PM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/14/19 10:38PM
  Re: New cars are shitRe: Stephen Keller Stephen Keller 04/14/19 10:41PM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/14/19 11:41PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/15/19 01:38PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/14/19 08:04PM
  Re: New cars are shitRe: Stephen Keller Stephen Keller 04/14/19 10:27PM
  Re: New cars are shitRe: Paola De Leon Paola De Leon 04/14/19 10:31PM
  Re: New cars are shitRe: Stephen Keller Stephen Keller 04/14/19 10:34PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/14/19 08:09PM
  Re: New cars are shitRe: Paola De Leon Paola De Leon 04/14/19 08:42PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/14/19 09:08PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/14/19 10:44PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/14/19 11:32PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/15/19 12:29AM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/15/19 07:33AM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/15/19 08:50AM
  Re: New cars are shitRe: Paola De Leon Paola De Leon 04/15/19 11:15AM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/15/19 10:03AM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/15/19 07:20PM
  Re: New cars are shitRe: Andrew Squiggman Andrew Squiggman 04/15/19 08:35PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/15/19 08:40PM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/16/19 12:12AM
  Re: New cars are shitRe: Andrew Squiggman Andrew Squiggman 04/16/19 12:37AM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/16/19 01:32AM
  Re: New cars are shitRe: kevin Smellaflange kevin Smellaflange 04/15/19 10:33AM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/15/19 12:47PM
  Re: New cars are shitRe: Dirty30 Dillon Dirty30 Dillon 04/15/19 01:30PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/15/19 12:49PM
  Re: New cars are shitRe: Paola De Leon Paola De Leon 04/15/19 01:28PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/15/19 07:45PM
  Re: New cars are shitRe: Paola De Leon Paola De Leon 04/15/19 07:47PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/15/19 07:59PM
  Re: New cars are shitRe: Dirty30 Dillon Dirty30 Dillon 04/17/19 01:22PM
  Re: New cars are shitRe: Paola De Leon Paola De Leon 04/15/19 08:25PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/15/19 11:21PM
  Re: New cars are shitRe: Paola De Leon Paola De Leon 04/15/19 11:48PM
  Re: New cars are shitRe: Andrew Squiggman Andrew Squiggman 04/16/19 12:01AM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/15/19 08:32PM
  Re: Burned-out, incompetent ex-mechanics are shitRe: Paola De Leon Paola De Leon 04/15/19 09:01PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/16/19 01:03AM
  Re: New cars are shitRe: Paola De Leon Paola De Leon 04/16/19 10:33AM
  Re: New cars are shitRe: Stephen Keller Stephen Keller 04/16/19 01:11AM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/16/19 01:20AM
  Re: New cars are shitRe: Jimmy Cincinnati Jimmy Cincinnati 04/16/19 10:29AM
  Re: New cars are shitRe: Stephen Keller Stephen Keller 04/16/19 03:14PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/16/19 08:24PM
  Re: New cars are shitRe: Born to be WillD Born to be WillD 04/17/19 09:38AM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/16/19 11:52PM
  Re: New cars are shitRe: Stephen Keller Stephen Keller 04/17/19 04:03AM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/17/19 04:28PM
  Re: New cars are shitRe: Thomas TPRF Thomas TPRF 04/17/19 12:09PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/17/19 01:27PM
  Re: New cars are shitRe: Born to be WillD Born to be WillD 04/17/19 01:50PM
  Re: New cars are shitRe: Thomas TPRF Thomas TPRF 04/17/19 03:18PM
  Re: New cars are shitRe: Paola De Leon Paola De Leon 04/17/19 05:08PM
  Re: New cars are shitRe: Jimmy Cincinnati Jimmy Cincinnati 04/17/19 07:22AM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/17/19 10:31AM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/17/19 02:00PM
  Re: New cars are shitRe: Dirty30 Dillon Dirty30 Dillon 04/17/19 02:21PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/17/19 02:39PM
  Re: New cars are shitRe: Dirty30 Dillon Dirty30 Dillon 04/17/19 02:49PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/17/19 03:40PM
  Re: New cars are shitRe: Dirty30 Dillon Dirty30 Dillon 04/17/19 04:05PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/17/19 04:36PM
  Re: New cars are shitRe: Dirty30 Dillon Dirty30 Dillon 04/17/19 04:41PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/17/19 04:39PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/17/19 04:40PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/17/19 04:47PM
  Re: New cars are shitRe: Dirty30 Dillon Dirty30 Dillon 04/17/19 05:15PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/17/19 05:28PM
  Re: New cars are shitRe: Dirty30 Dillon Dirty30 Dillon 04/17/19 10:05PM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/18/19 08:33AM
  Re: New cars are shitRe: P8R . P8R . 04/17/19 10:06PM
  Re: New cars are shitRe: Dirty30 Dillon Dirty30 Dillon 04/17/19 10:07PM
  Re: New cars are shitRe: P8R . P8R . 04/17/19 10:09PM
  Re: New cars are shitRe: Dirty30 Dillon Dirty30 Dillon 04/18/19 09:06AM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/17/19 10:17PM
  Re: New cars are shitRe: Jimmy Cincinnati Jimmy Cincinnati 04/18/19 07:42AM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/18/19 11:25AM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/18/19 08:53AM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/18/19 09:09AM
  Re: New cars are shitRe: Dirty30 Dillon Dirty30 Dillon 04/18/19 10:09AM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/18/19 10:22AM
  Re: New cars are shitRe: Dirty30 Dillon Dirty30 Dillon 04/18/19 10:24AM
  Re: New cars are shitRe: Jimmy Cincinnati Jimmy Cincinnati 04/18/19 11:53AM
  Re: New cars are shitRe: kevin Smellaflange kevin Smellaflange 04/18/19 12:16PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/18/19 12:19PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/18/19 12:26PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/18/19 12:39PM
  Re: New cars are shitRe: kevin Smellaflange kevin Smellaflange 04/18/19 12:40PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/18/19 12:45PM
  Re: New cars are shitRe: Paola De Leon Paola De Leon 04/18/19 07:12PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/18/19 12:55PM
  Re: New cars are shitRe: kevin Smellaflange kevin Smellaflange 04/18/19 01:10PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/18/19 01:14PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/18/19 01:17PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/18/19 01:54PM
  Re: New cars are shitRe: Jimmy Cincinnati Jimmy Cincinnati 04/18/19 02:01PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/18/19 02:12PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/18/19 04:28PM
  Re: New cars are shitRe: kevin Smellaflange kevin Smellaflange 04/18/19 05:11PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/18/19 06:07PM
  Re: New cars are shitRe: Dirty30 Dillon Dirty30 Dillon 04/18/19 11:06PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/18/19 06:34PM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/18/19 06:39PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/18/19 06:58PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/18/19 07:52PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/18/19 08:47PM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/19/19 03:31AM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/18/19 09:22PM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/18/19 10:52PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/18/19 11:00PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/18/19 11:52PM
  Re: New cars are shitRe: Dirty30 Dillon Dirty30 Dillon 04/19/19 07:14AM
  Re: New cars are shitRe: Stephen Keller Stephen Keller 04/19/19 07:58PM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/19/19 09:03PM
  Re: New cars are shitRe: Stephen Keller Stephen Keller 04/19/19 09:11PM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/19/19 09:21PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/18/19 11:59PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/19/19 04:07AM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/19/19 07:44AM
  Re: New cars are shitRe: Jimmy Cincinnati Jimmy Cincinnati 04/19/19 08:05AM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/19/19 08:15AM
  Re: New cars are shitRe: Jimmy Cincinnati Jimmy Cincinnati 04/19/19 09:50AM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/19/19 10:51AM
  Re: New cars are shitRe: Jimmy Cincinnati Jimmy Cincinnati 04/19/19 11:34AM
  Re: New cars are shitRe: Paola De Leon Paola De Leon 04/19/19 11:56AM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/19/19 01:27PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/19/19 11:37AM
  Re: New cars are shitRe: Jimmy Cincinnati Jimmy Cincinnati 04/19/19 11:56AM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/19/19 01:24PM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/19/19 01:36PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/19/19 01:59PM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/19/19 07:12PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/19/19 02:03PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/19/19 02:14PM
  Re: New cars are shitRe: Jeff Parr Jeff Parr 04/20/19 04:18AM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/20/19 07:43AM
  Re: New cars are shitRe: kevin Smellaflange kevin Smellaflange 04/20/19 12:08PM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/20/19 12:31PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/20/19 02:30PM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/20/19 03:32PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/20/19 04:40PM
  Re: New cars are shitRe: P8R . P8R . 04/20/19 06:24PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/20/19 06:52PM
  Re: New cars are shitRe: kevin Smellaflange kevin Smellaflange 04/20/19 07:18PM
  Re: New cars are shitRe: P8R . P8R . 04/20/19 09:58PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/20/19 11:47PM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/21/19 11:58AM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/21/19 07:25PM
  Re: New cars are shitRe: Overpriced Parts Overpriced Parts 04/22/19 05:32PM
  Re: New cars are shitRe: Andrew Squiggman Andrew Squiggman 04/21/19 12:08AM
  Re: New cars are shitRe: Dirty30 Dillon Dirty30 Dillon 04/21/19 12:08PM
  Re: New cars are shitRe: Stephen Keller Stephen Keller 04/21/19 03:22PM
  Re: New cars are shitRe: A Zed A Zed 04/22/19 09:01AM
  Re: New cars are shitRe: Jimmy Cincinnati Jimmy Cincinnati 04/22/19 09:13AM
  Re: New cars are shitRe: A Zed A Zed 04/22/19 09:28AM
  Re: New cars are shitRe: kevin Smellaflange kevin Smellaflange 04/22/19 09:49AM
  Re: New cars are shitRe: A Zed A Zed 04/22/19 09:49AM
  Re: New cars are shitRe: Born to be WillD Born to be WillD 04/22/19 11:57AM
  Re: New cars are shitRe: Stephen Keller Stephen Keller 04/22/19 02:32PM
  Re: New cars are shitRe: Dirty30 Dillon Dirty30 Dillon 04/22/19 02:43PM
  Re: New cars are shitRe: Stephen Keller Stephen Keller 04/22/19 02:47PM
  Re: New cars are shitRe: Jimmy Cincinnati Jimmy Cincinnati 04/22/19 01:18PM
  Re: New cars are shitRe: kevin Smellaflange kevin Smellaflange 04/22/19 02:55PM
  Re: New cars are shitRe: Overpriced Parts Overpriced Parts 04/22/19 04:54PM
  Re: New cars are shitRe: Dirty30 Dillon Dirty30 Dillon 04/22/19 05:18PM
  Re: New cars are shitRe: kevin Smellaflange kevin Smellaflange 04/22/19 05:45PM
  Re: New cars are shitRe: Jimmy Cincinnati Jimmy Cincinnati 04/22/19 04:57PM
  Re: New cars are shitRe: Overpriced Parts Overpriced Parts 04/22/19 05:47PM
  Re: New cars are shitRe: kevin Smellaflange kevin Smellaflange 04/22/19 06:01PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/22/19 06:15PM
  Re: New cars are shitRe: A Zed A Zed 04/22/19 07:13PM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/22/19 07:44PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/22/19 08:31PM
  Re: New cars are shitRe: A Zed A Zed 04/22/19 11:06PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/22/19 11:50PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/22/19 08:32PM
  Re: New cars are shitRe: Born to be WillD Born to be WillD 04/23/19 11:29AM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/23/19 12:30PM
  Re: New cars are shitRe: Born to be WillD Born to be WillD 04/23/19 01:59PM
  Re: New cars are shitRe: Overpriced Parts Overpriced Parts 04/23/19 12:42PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/23/19 01:18PM
  Re: New cars are shitRe: kevin Smellaflange kevin Smellaflange 04/23/19 01:25PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/23/19 09:23PM
  Re: New cars are shitRe: Stephen Keller Stephen Keller 04/23/19 02:12PM
  Re: New cars are shitRe: Overpriced Parts Overpriced Parts 04/23/19 03:41PM
  Re: New cars are shitRe: Born to be WillD Born to be WillD 04/24/19 09:36AM
  Re: New cars are shitRe: Born to be WillD Born to be WillD 04/23/19 02:03PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/23/19 02:11PM
  Re: New cars are shitRe: Dirty30 Dillon Dirty30 Dillon 04/23/19 02:28PM
  Re: New cars are shitRe: kevin Smellaflange kevin Smellaflange 04/23/19 02:26PM
  Re: New cars are shitRe: Born to be WillD Born to be WillD 04/23/19 02:54PM
  Re: New cars are shitRe: Overpriced Parts Overpriced Parts 04/23/19 03:48PM
  Re: New cars are shitRe: Born to be WillD Born to be WillD 04/23/19 02:47PM
  Re: New cars are shitRe: Dirty30 Dillon Dirty30 Dillon 04/23/19 03:46PM
  Re: New cars are shitRe: Overpriced Parts Overpriced Parts 04/23/19 03:53PM
  Re: New cars are shitRe: Dirty30 Dillon Dirty30 Dillon 04/23/19 04:14PM
  Re: New cars are shitRe: kevin Smellaflange kevin Smellaflange 04/23/19 04:36PM
  Re: New cars are shitRe: Overpriced Parts Overpriced Parts 04/23/19 07:31PM
  Re: New cars are shitRe: Stephen Keller Stephen Keller 04/23/19 10:23PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/24/19 01:04AM
  Re: New cars are shitRe: A Zed A Zed 04/23/19 09:48PM
  Re: New cars are shitRe: kevin Smellaflange kevin Smellaflange 04/23/19 07:58PM
  Re: New cars are shitRe: Overpriced Parts Overpriced Parts 04/23/19 09:17PM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/23/19 10:51PM
  Re: New cars are shitRe: Stephen Keller Stephen Keller 04/24/19 01:10AM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/24/19 01:30AM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/24/19 01:18AM
  Re: New cars are shitRe: Stephen Keller Stephen Keller 04/24/19 02:58AM
  Re: New cars are shitRe: P8R . P8R . 04/24/19 09:54AM
  Re: New cars are shitRe: Born to be WillD Born to be WillD 04/24/19 04:13PM
  Re: New cars are shitRe: Overpriced Parts Overpriced Parts 04/24/19 04:39PM
  Re: New cars are shitRe: Born to be WillD Born to be WillD 04/25/19 10:11AM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/24/19 02:55AM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/25/19 01:07AM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/25/19 06:52AM
  Re: New cars are shitRe: Stephen Keller Stephen Keller 04/25/19 01:27PM
  Re: New cars are shitRe: Dirty30 Dillon Dirty30 Dillon 04/25/19 08:47AM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/25/19 11:52PM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/26/19 01:02AM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/26/19 01:44AM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/26/19 07:35AM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/25/19 10:13AM
  Re: New cars are shitRe: Born to be WillD Born to be WillD 04/25/19 10:36AM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/25/19 12:56PM
  Re: New cars are shitRe: Jimmy Cincinnati Jimmy Cincinnati 04/26/19 09:20AM
  Re: New cars are shitRe: kevin Smellaflange kevin Smellaflange 04/26/19 09:26AM
  Re: New cars are shitRe: Jimmy Cincinnati Jimmy Cincinnati 04/26/19 09:37AM
  Re: New cars are shitRe: Born to be WillD Born to be WillD 04/26/19 09:46AM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/26/19 09:40AM
  Re: New cars are shitRe: Jimmy Cincinnati Jimmy Cincinnati 04/26/19 11:18AM
  Re: New cars are shitRe: Born to be WillD Born to be WillD 04/26/19 11:50AM
  Re: New cars are shitRe: Stephen Keller Stephen Keller 04/26/19 12:01PM
  Re: New cars are shitRe: Jimmy Cincinnati Jimmy Cincinnati 04/26/19 11:54AM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/26/19 12:04PM
  Re: New cars are shitRe: kevin Smellaflange kevin Smellaflange 04/26/19 12:20PM
  Re: New cars are shitRe: A Zed A Zed 04/26/19 02:06PM
  Re: New cars are shitRe: Jimmy Cincinnati Jimmy Cincinnati 04/26/19 12:21PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/26/19 12:43PM
  Re: New cars are shitRe: Jimmy Cincinnati Jimmy Cincinnati 04/26/19 02:00PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/26/19 02:11PM
  Re: New cars are shitRe: Thomas TPRF Thomas TPRF 04/26/19 02:31PM
  Re: New cars are shitRe: A Zed A Zed 04/26/19 02:42PM
  Re: New cars are shitRe: kevin Smellaflange kevin Smellaflange 04/26/19 02:55PM
  Re: New cars are shitRe: Thomas TPRF Thomas TPRF 04/26/19 03:29PM
  Re: New cars are shitRe: Thomas TPRF Thomas TPRF 04/26/19 03:25PM
  Re: New cars are shitRe: A Zed A Zed 04/26/19 03:28PM
  Re: New cars are shitRe: Thomas TPRF Thomas TPRF 04/26/19 03:30PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/26/19 03:36PM
  Re: New cars are shitRe: Thomas TPRF Thomas TPRF 04/26/19 04:12PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/26/19 04:20PM
  Re: New cars are shitRe: Thomas TPRF Thomas TPRF 04/26/19 04:31PM
  Re: New cars are shitRe: A Zed A Zed 04/26/19 03:37PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/26/19 02:37PM
  Re: New cars are shitRe: Jimmy Cincinnati Jimmy Cincinnati 04/26/19 02:56PM
  Re: New cars are shitRe: Stephen Keller Stephen Keller 04/26/19 03:51PM
  Re: New cars are shitRe: Jimmy Cincinnati Jimmy Cincinnati 04/26/19 04:04PM
  Re: New cars are shitRe: A Zed A Zed 04/26/19 04:23PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/26/19 05:54PM
  Re: New cars are shitRe: Born to be WillD Born to be WillD 04/29/19 01:18PM
  Re: New cars are shitRe: Overpriced Parts Overpriced Parts 04/29/19 02:42PM
  Re: New cars are shitRe: kevin Smellaflange kevin Smellaflange 04/29/19 03:26PM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/29/19 06:28PM
  Re: New cars are shitRe: kevin Smellaflange kevin Smellaflange 04/29/19 06:55PM
  Re: New cars are shitRe: A Zed A Zed 04/26/19 06:19PM
  Re: New cars are shitRe: Overpriced Parts Overpriced Parts 04/26/19 06:37PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/26/19 06:47PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/26/19 07:06PM
  Re: New cars are shitRe: A Zed A Zed 04/26/19 08:09PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/26/19 09:23PM
  Re: New cars are shitRe: A Zed A Zed 04/26/19 10:00PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/26/19 10:48PM
  Re: New cars are shitRe: Thomas TPRF Thomas TPRF 04/27/19 12:34AM
  Re: New cars are shitRe: Dirty30 Dillon Dirty30 Dillon 04/29/19 02:08PM
  Re: New cars are shitRe: Born to be WillD Born to be WillD 04/29/19 01:36PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/27/19 01:08AM
  Re: New cars are shitRe: A Zed A Zed 04/27/19 02:22AM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/27/19 06:33AM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/27/19 06:39AM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/27/19 08:30AM
  Re: New cars are shitRe: A Zed A Zed 04/27/19 10:59AM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/27/19 11:31AM
  Re: New cars are shitRe: kevin Smellaflange kevin Smellaflange 04/27/19 12:25PM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/27/19 12:53PM
  Re: New cars are shitRe: Thomas TPRF Thomas TPRF 04/27/19 12:31PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/27/19 12:38PM
  Re: New cars are shitRe: Thomas TPRF Thomas TPRF 04/27/19 04:06PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/27/19 01:05PM
  Re: New cars are shitRe: kevin Smellaflange kevin Smellaflange 04/27/19 04:25PM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/28/19 03:00PM
  Re: New cars are shitRe: __̴ı̴̴̡̡̡ ̡͌l̡̡̡ ̡͌l̡*̡̡ ̴̡ı̴̴̡ ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡͡ ̲|̡̡̡ ̡ ̴̡ı̴̡̡ ̡͌l̡̡̡̡.__ __̴ı̴̴̡̡̡ ̡͌l̡̡̡ ̡͌l̡*̡̡ ̴̡ı̴̴̡ ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡͡ ̲|̡̡̡ ̡ ̴̡ı̴̡̡ ̡͌l̡̡̡̡.__ 04/28/19 08:45PM
  Re: New cars are shitRe: A Zed A Zed 04/28/19 10:05PM
  Re: New cars are shitRe: A Zed A Zed 04/29/19 06:59PM
  Re: New cars are shitRe: kevin Smellaflange kevin Smellaflange 04/29/19 07:02PM
  Re: New cars are shitRe: A Zed A Zed 04/29/19 07:03PM
  Re: New cars are shitRe: kevin Smellaflange kevin Smellaflange 04/29/19 07:06PM
  Re: New cars are shitRe: A Zed A Zed 04/29/19 07:07PM
  Re: New cars are shitRe: kevin Smellaflange kevin Smellaflange 04/29/19 07:10PM
  Re: New cars are shitRe: kevin Smellaflange kevin Smellaflange 04/30/19 03:53PM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/29/19 08:55PM
  Re: New cars are shitRe: kevin Smellaflange kevin Smellaflange 04/29/19 09:49PM
  Re: New cars are shitRe: kevin Smellaflange kevin Smellaflange 04/29/19 09:53PM
  Re: New cars are shitRe: kevin Smellaflange kevin Smellaflange 04/29/19 09:57PM
  Re: New cars are shitRe: kevin Smellaflange kevin Smellaflange 04/29/19 10:04PM
  Re: New cars are shitRe: kevin Smellaflange kevin Smellaflange 04/29/19 10:09PM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/30/19 05:39AM
  Re: New cars are shitRe: kevin Smellaflange kevin Smellaflange 04/30/19 08:24AM
  Re: New cars are shitRe: Dirty30 Dillon Dirty30 Dillon 04/30/19 10:45AM
  Re: New cars are shitRe: kevin smellaflange kevin smellaflange 04/30/19 11:39AM
  Re: New cars are shitRe: Dirty30 Dillon Dirty30 Dillon 04/30/19 11:46AM
  Re: New cars are shitRe: kevin smellaflange kevin smellaflange 04/30/19 12:05PM
  Re: New cars are shitRe: kevin smellaflange kevin smellaflange 04/30/19 05:23PM
  Re: New cars are shitRe: Thomas TPRF Thomas TPRF 04/30/19 08:30PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/30/19 09:52PM
  Re: New cars are shitRe: kevin smellaflange kevin smellaflange 05/01/19 11:39AM
  Re: New cars are shitRe: kevin smellaflange kevin smellaflange 05/01/19 03:35PM
  Re: New cars are shitRe: kevin smellaflange kevin smellaflange 05/02/19 09:11AM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 05/10/19 01:13PM
  Re: New cars are shitRe: Stephen Keller Stephen Keller 05/10/19 06:12PM
  Re: New cars are shitRe: Born to be WillD Born to be WillD 05/13/19 03:16PM
  Re: New cars are shitRe: Thomas TPRF Thomas TPRF 05/13/19 06:00PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 05/10/19 05:53PM
  Re: New cars are shitRe: Thomas TPRF Thomas TPRF 05/10/19 06:52PM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 05/11/19 10:31AM
  Re: New cars are shitRe: Thomas TPRF Thomas TPRF 05/11/19 04:20PM
  Re: New cars are shitRe: Stephen Keller Stephen Keller 05/11/19 07:33PM
  Re: New cars are shitRe: Thomas TPRF Thomas TPRF 05/11/19 08:33PM
  Re: New cars are shitRe: Stephen Keller Stephen Keller 05/11/19 09:06PM
  Re: New cars are shitRe: Thomas TPRF Thomas TPRF 05/12/19 03:03PM
  Re: New cars are shitRe: Stephen Keller Stephen Keller 05/12/19 06:04PM
  Re: New cars are shitRe: Don Ohio Don Ohio 05/11/19 11:25PM
  Re: New cars are shitRe: Stephen Keller Stephen Keller 05/12/19 06:03PM
  Re: New cars are shitRe: Piston Port Piston Port 05/13/19 10:02AM
  Re: New cars are shitRe: Don Ohio Don Ohio 05/14/19 01:03AM
  Re: New cars are shitRe: Thomas TPRF Thomas TPRF 05/14/19 09:25AM
  Re: New cars are shitRe: Don Ohio Don Ohio 05/14/19 10:43AM
  Re: New cars are shitRe: Don Ohio Don Ohio 05/14/19 09:26PM
  Re: New cars are shitRe: Thomas TPRF Thomas TPRF 05/14/19 10:42PM
  Re: New cars are shitRe: Don Ohio Don Ohio 05/14/19 11:40PM
  Re: New cars are shitRe: jayson sumpter jayson sumpter 05/15/19 08:52AM
  Re: New cars are shitRe: jayson sumpter jayson sumpter 05/15/19 08:59AM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 05/14/19 11:21PM
  Re: New cars are shitRe: Born to be WillD Born to be WillD 05/15/19 10:03AM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 05/15/19 01:58PM
  Re: New cars are shitRe: Stephen Keller Stephen Keller 05/15/19 02:24PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 05/15/19 03:41PM
  Re: New cars are shitRe: Don Ohio Don Ohio 05/15/19 03:57PM
  Re: New cars are shitRe: ERIC from Idaho! ERIC from Idaho! 05/15/19 04:18PM
  Re: New cars are shitRe: Jose Leon Jose Leon 05/17/19 02:33PM
  Re: New cars are shitRe: Thomas TPRF Thomas TPRF 05/17/19 05:08PM
  Re: New cars are shitRe: Stephen Keller Stephen Keller 05/17/19 07:37PM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 05/24/19 02:25PM
  Re: New cars are shitRe: Thomas TPRF Thomas TPRF 05/24/19 06:54PM
  Re: New cars are shitRe: Don Ohio Don Ohio 05/15/19 06:51PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 05/15/19 09:22PM
