Re: New cars are shit
Paola De Leon /
> Blaine- The artist formerly known as Plumber Crack "(OFMC)" Wrote:
> Run the tap with grease in the flutes if you’re so scared of aluminum
> chips. I run it dry. I put the cylinder on top dead and run the tap dry.
> Then i insert a piece of 1/4” brake line tubing through spark plug hole.
> Blow air in. Chips fly out. Check it with a bore scope. It’s like a
> magic show. If there’s any chip or two left in there, the cat won’t
> care.
> I used to leave an intake valve open and air up the intake through a
> a vacuum port so the chips are pushed out as you tap, but vacuum ports
> can be hard to find lately, if they even have one.
> The last dozen or two heli-coils i’ve done have all been on 04-08 5.4
> 4 Triton motors.
> If you have spark plug thread issues, it’s not because it’s an
> an aluminum head.
> If you have thread issues, of course it’s going to be an aluminum head
> d because 99.999% of the cars on the road have aluminum heads.
> And 99.99% of the time, thread failure is not due to OVER-torqued plugs.
> It’s because they’re UNDER-Torqued.
> When they’re under-torqued they can become loose in the hole and the
> compression eventually beats the threads out.
> A plug that doesn’t want to thread out isn’t because it was over
> r torqued. It was under torqued, compression gases escape through the
> threads and leave carbon deposits, virtually welding the plug in. This
> happens more often on taped seat plugs.
> Both of these scenarios happen on aluminum and cast iron heads.
> Carb cleaner will loosen most stuck plugs in a few minutes with some
> back and forth of the plug. Don’t be a moron and just try to run it out.
> If the plug has a crush washer, crush that bitch. Don’t be scared.
> . You’ll feel when it’s done crushing. If it’s a tapered seat, make it
> tight, not “oh i’m scared because it’s aluminum” sissy tight.
^^LOL. You and my dad are cut from the same cloth.
There seems to be a lot of misinformation and disinformation on this thread from folks who believe they know a thing or two. The great irony is that the one person on here who claims to be a man of faith, believing in things that have absolutely no substantiation, seems to be the most narrow-minded of all posters here, is by far the most ignorant, and in complete denial of his ignorance.
  New cars are shitTopic by: Angry Hipster Angry Hipster 03/30/19 05:36PM
  Re: New cars are shitRe: Chöschi21 C.K. Chöschi21 C.K. 03/30/19 06:02PM
  Re: New cars are shitRe: Daniel '' Daniel '' 03/30/19 06:13PM
  Re: New cars are shitRe: Blake MD No PM Plz Blake MD No PM Plz 03/30/19 06:20PM
  Re: New cars are shitRe: Thomas Smith Thomas Smith 03/30/19 06:33PM
  Re: New cars are shitRe: Jeff Parr Jeff Parr 03/30/19 07:40PM
  Re: New cars are shitRe: Stephen Keller Stephen Keller 03/30/19 08:00PM
  Re: New cars are shitRe: Born to be WillD Born to be WillD 03/30/19 08:08PM
  Re: New cars are shitRe: Stephen Keller Stephen Keller 03/30/19 08:19PM
  Re: New cars are shitRe: __̴ı̴̴̡̡̡ ̡͌l̡̡̡ ̡͌l̡*̡̡ ̴̡ı̴̴̡ ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡͡ ̲|̡̡̡ ̡ ̴̡ı̴̡̡ ̡͌l̡̡̡̡.__ __̴ı̴̴̡̡̡ ̡͌l̡̡̡ ̡͌l̡*̡̡ ̴̡ı̴̴̡ ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡͡ ̲|̡̡̡ ̡ ̴̡ı̴̡̡ ̡͌l̡̡̡̡.__ 03/30/19 08:14PM
  Re: New cars are shitRe: Born to be WillD Born to be WillD 04/03/19 04:15PM
  Re: New cars are shitRe: Stephen Keller Stephen Keller 04/03/19 07:09PM
  Re: New cars are shitRe: Don Ohio Don Ohio 03/30/19 10:27PM
  Re: New cars are shitRe: __̴ı̴̴̡̡̡ ̡͌l̡̡̡ ̡͌l̡*̡̡ ̴̡ı̴̴̡ ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡͡ ̲|̡̡̡ ̡ ̴̡ı̴̡̡ ̡͌l̡̡̡̡.__ __̴ı̴̴̡̡̡ ̡͌l̡̡̡ ̡͌l̡*̡̡ ̴̡ı̴̴̡ ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡͡ ̲|̡̡̡ ̡ ̴̡ı̴̡̡ ̡͌l̡̡̡̡.__ 03/30/19 10:40PM
  Re: New cars are shitRe: Don Ohio Don Ohio 03/30/19 11:17PM
  Re: New cars are shitRe: Paola De Leon Paola De Leon 04/15/19 12:17AM
  Re: New cars are shitRe: Don Ohio Don Ohio 03/31/19 12:15AM
  Re: New cars are shitRe: __̴ı̴̴̡̡̡ ̡͌l̡̡̡ ̡͌l̡*̡̡ ̴̡ı̴̴̡ ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡͡ ̲|̡̡̡ ̡ ̴̡ı̴̡̡ ̡͌l̡̡̡̡.__ __̴ı̴̴̡̡̡ ̡͌l̡̡̡ ̡͌l̡*̡̡ ̴̡ı̴̴̡ ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡͡ ̲|̡̡̡ ̡ ̴̡ı̴̡̡ ̡͌l̡̡̡̡.__ 03/31/19 01:00AM
  Re: New cars are shitRe: Brad William Brad William 03/31/19 02:23PM
  Re: New cars are shitRe: kenny s kenny s 03/31/19 02:32PM
  Re: New cars are shitRe: Brad William Brad William 03/31/19 02:43PM
  Re: New cars are shitRe: Don Ohio Don Ohio 03/31/19 02:45PM
  Re: New cars are shitRe: kevin Smellaflange kevin Smellaflange 03/31/19 02:58PM
  Re: New cars are shitRe: Thomas TPRF Thomas TPRF 04/02/19 04:03PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 03/31/19 04:26PM
  Re: New cars are shitRe: Overpriced Parts Overpriced Parts 03/31/19 05:29PM
  Re: New cars are shitRe: Jarod V. Jarod V. 04/09/19 05:39PM
  Re: New cars are shitRe: Don Ohio Don Ohio 03/31/19 04:42PM
  Re: New cars are shitRe: Paola De Leon Paola De Leon 04/14/19 10:20PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 03/31/19 06:08PM
  Re: New cars are shitRe: Overpriced Parts Overpriced Parts 04/02/19 04:22PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/02/19 05:17PM
  Re: New cars are shitRe: Thomas TPRF Thomas TPRF 04/03/19 09:47AM
  Re: New cars are shitRe: Born to be WillD Born to be WillD 04/04/19 01:42PM
  Re: New cars are shitRe: Moped Lar (OFMC) Moped Lar (OFMC) 04/03/19 09:47AM
  Re: New cars are shitRe: Andrew Squiggman Andrew Squiggman 04/03/19 10:53AM
  Re: New cars are shitRe: Thomas TPRF Thomas TPRF 04/05/19 09:15AM
  Re: New cars are shitRe: Stephen Keller Stephen Keller 04/05/19 01:53PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/05/19 01:58PM
  Re: New cars are shitRe: Stephen Keller Stephen Keller 04/05/19 02:00PM
  Re: New cars are shitRe: Paola De Leon Paola De Leon 04/14/19 11:42PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/15/19 12:10AM
  Re: New cars are shitRe: __̴ı̴̴̡̡̡ ̡͌l̡̡̡ ̡͌l̡*̡̡ ̴̡ı̴̴̡ ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡͡ ̲|̡̡̡ ̡ ̴̡ı̴̡̡ ̡͌l̡̡̡̡.__ __̴ı̴̴̡̡̡ ̡͌l̡̡̡ ̡͌l̡*̡̡ ̴̡ı̴̴̡ ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡͡ ̲|̡̡̡ ̡ ̴̡ı̴̡̡ ̡͌l̡̡̡̡.__ 03/31/19 06:30PM
  Re: New cars are shitRe: Chris Szuba Chris Szuba 04/02/19 07:40AM
  Re: New cars are shitRe: I M I M 04/03/19 09:15AM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/15/19 12:06AM
  Re: New cars are shitRe: I M I M 04/25/19 07:01AM
  Re: New cars are shitRe: kevin Smellaflange kevin Smellaflange 04/25/19 08:13AM
  Re: New cars are shitRe: Jeff Parr Jeff Parr 04/03/19 11:08AM
  Re: New cars are shitRe: Moped Lar (OFMC) Moped Lar (OFMC) 04/03/19 11:19AM
  Re: New cars are shitRe: Jimmy Cincinnati Jimmy Cincinnati 04/03/19 11:12AM
  Re: New cars are shitRe: jayson sumpter jayson sumpter 04/03/19 11:28AM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/03/19 04:53PM
  Re: New cars are shitRe: Andrew Squiggman Andrew Squiggman 04/03/19 04:55PM
  Re: New cars are shitRe: Jeff Parr Jeff Parr 04/03/19 04:58PM
  Re: New cars are shitRe: Jimmy Cincinnati Jimmy Cincinnati 04/03/19 09:37PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/04/19 08:45AM
  Re: New cars are shitRe: informatique formation informatique formation 04/04/19 04:56PM
  Re: New cars are shitRe: Born to be WillD Born to be WillD 04/08/19 11:51AM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/08/19 12:20PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/08/19 06:33PM
  Re: New cars are shitRe: Born to be WillD Born to be WillD 04/16/19 10:20AM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/16/19 10:51AM
  Re: New cars are shitRe: Andrew Squiggman Andrew Squiggman 04/17/19 12:04AM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/17/19 12:10AM
  Re: New cars are shitRe: Paola De Leon Paola De Leon 04/17/19 01:08AM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/17/19 01:17AM
  Re: New cars are shitRe: Paola De Leon Paola De Leon 04/17/19 01:42AM
  Re: New cars are shitRe: Daniel '' Daniel '' 04/17/19 12:52PM
  Re: New cars are shitRe: kevin Smellaflange kevin Smellaflange 04/04/19 07:51PM
  Re: New cars are shitRe: Stephen Keller Stephen Keller 04/04/19 10:13PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/05/19 09:51AM
  Re: New cars are shitRe: Thomas TPRF Thomas TPRF 04/05/19 10:00AM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/05/19 01:08PM
  Re: New cars are shitRe: Jimmy Cincinnati Jimmy Cincinnati 04/05/19 12:36PM
  Re: New cars are shitRe: Jimmy Cincinnati Jimmy Cincinnati 04/05/19 03:23PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/05/19 04:29PM
  Re: New cars are shitRe: kevin Smellaflange kevin Smellaflange 04/07/19 11:38AM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/05/19 04:41PM
  Re: New cars are shitRe: Jimmy Cincinnati Jimmy Cincinnati 04/05/19 05:21PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/05/19 06:39PM
  Re: New cars are shitRe: Stephen Keller Stephen Keller 04/05/19 07:18PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/06/19 12:02AM
  Re: New cars are shitRe: __̴ı̴̴̡̡̡ ̡͌l̡̡̡ ̡͌l̡*̡̡ ̴̡ı̴̴̡ ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡͡ ̲|̡̡̡ ̡ ̴̡ı̴̡̡ ̡͌l̡̡̡̡.__ __̴ı̴̴̡̡̡ ̡͌l̡̡̡ ̡͌l̡*̡̡ ̴̡ı̴̴̡ ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡͡ ̲|̡̡̡ ̡ ̴̡ı̴̡̡ ̡͌l̡̡̡̡.__ 04/06/19 09:13PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/07/19 05:21PM
  Re: New cars are shitRe: Jimmy Cincinnati Jimmy Cincinnati 04/08/19 12:53PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/08/19 04:09PM
  Re: New cars are shitRe: Born to be WillD Born to be WillD 04/09/19 08:54AM
  Re: New cars are shitRe: Chöschi21 C.K. Chöschi21 C.K. 04/08/19 05:04PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/08/19 06:12PM
  Re: New cars are shitRe: Chöschi21 C.K. Chöschi21 C.K. 04/10/19 06:56AM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/08/19 07:37PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/09/19 12:58AM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/09/19 09:52AM
  Re: New cars are shitRe: Born to be WillD Born to be WillD 04/10/19 10:15AM
  Re: New cars are shitRe: Thomas TPRF Thomas TPRF 04/13/19 01:22AM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/13/19 01:41AM
  Re: New cars are shitRe: Thomas TPRF Thomas TPRF 04/13/19 11:04AM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/09/19 10:08AM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/09/19 12:45PM
  Re: New cars are shitRe: Jimmy Cincinnati Jimmy Cincinnati 04/09/19 02:11PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/09/19 02:15PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/09/19 03:07PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/09/19 05:51PM
  Re: New cars are shitRe: Jarod V. Jarod V. 04/09/19 07:24PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/09/19 07:57PM
  Re: New cars are shitRe: Jarod V. Jarod V. 04/09/19 09:26PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/09/19 09:47PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/10/19 12:42AM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/14/19 04:12PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/10/19 10:26AM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/10/19 10:58AM
  Re: New cars are shitRe: Jimmy Cincinnati Jimmy Cincinnati 04/10/19 12:16PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/10/19 12:22PM
  Re: New cars are shitRe: Andrew Squiggman Andrew Squiggman 04/10/19 12:45PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/10/19 12:19PM
  Re: New cars are shitRe: Dirty30 Dillon Dirty30 Dillon 04/10/19 03:37PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/10/19 03:51PM
  Re: New cars are shitRe: Dirty30 Dillon Dirty30 Dillon 04/10/19 04:05PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/10/19 04:12PM
  Re: New cars are shitRe: Dirty30 Dillon Dirty30 Dillon 04/10/19 04:14PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/10/19 04:15PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/10/19 04:18PM
  Re: New cars are shitRe: Dirty30 Dillon Dirty30 Dillon 04/10/19 04:34PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/10/19 04:40PM
  Re: New cars are shitRe: Dirty30 Dillon Dirty30 Dillon 04/10/19 04:57PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/10/19 05:02PM
  Re: New cars are shitRe: Dirty30 Dillon Dirty30 Dillon 04/10/19 05:08PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/10/19 05:13PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/10/19 05:50PM
  Re: New cars are shitRe: Stephen Keller Stephen Keller 04/10/19 07:10PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/10/19 07:51PM
  Re: New cars are shitRe: Stephen Keller Stephen Keller 04/10/19 10:30PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/11/19 01:48AM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/10/19 09:54PM
  Re: New cars are shitRe: Jimmy Cincinnati Jimmy Cincinnati 04/11/19 07:51AM
  Re: New cars are shitRe: Born to be WillD Born to be WillD 04/11/19 09:35AM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/11/19 10:25AM
  Re: New cars are shitRe: Jimmy Cincinnati Jimmy Cincinnati 04/11/19 11:08AM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/12/19 12:56AM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/11/19 11:24AM
  Re: New cars are shitRe: P8R . P8R . 04/11/19 04:23PM
  Re: New cars are shitRe: Born to be WillD Born to be WillD 04/12/19 10:54AM
  Re: New cars are shitRe: P8R . P8R . 04/12/19 11:17AM
  Re: New cars are shitRe: Jimmy Cincinnati Jimmy Cincinnati 04/11/19 04:32PM
  Re: New cars are shitRe: Jimmy Cincinnati Jimmy Cincinnati 04/12/19 10:17AM
  Re: New cars are shitRe: Stephen Keller Stephen Keller 04/12/19 11:49AM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/13/19 01:13AM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/13/19 03:07PM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/14/19 12:54PM
  Re: New cars are shitRe: . chillywillie . chillywillie 04/14/19 01:20PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/14/19 04:23PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/14/19 08:01PM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/14/19 10:38PM
  Re: New cars are shitRe: Stephen Keller Stephen Keller 04/14/19 10:41PM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/14/19 11:41PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/15/19 01:38PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/14/19 08:04PM
  Re: New cars are shitRe: Stephen Keller Stephen Keller 04/14/19 10:27PM
  Re: New cars are shitRe: Paola De Leon Paola De Leon 04/14/19 10:31PM
  Re: New cars are shitRe: Stephen Keller Stephen Keller 04/14/19 10:34PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/14/19 08:09PM
  Re: New cars are shitRe: Paola De Leon Paola De Leon 04/14/19 08:42PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/14/19 09:08PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/14/19 10:44PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/14/19 11:32PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/15/19 12:29AM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/15/19 07:33AM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/15/19 08:50AM
  Re: New cars are shitRe: Paola De Leon Paola De Leon 04/15/19 11:15AM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/15/19 10:03AM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/15/19 07:20PM
  Re: New cars are shitRe: Andrew Squiggman Andrew Squiggman 04/15/19 08:35PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/15/19 08:40PM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/16/19 12:12AM
  Re: New cars are shitRe: Andrew Squiggman Andrew Squiggman 04/16/19 12:37AM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/16/19 01:32AM
  Re: New cars are shitRe: kevin Smellaflange kevin Smellaflange 04/15/19 10:33AM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/15/19 12:47PM
  Re: New cars are shitRe: Dirty30 Dillon Dirty30 Dillon 04/15/19 01:30PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/15/19 12:49PM
  Re: New cars are shitRe: Paola De Leon Paola De Leon 04/15/19 01:28PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/15/19 07:45PM
  Re: New cars are shitRe: Paola De Leon Paola De Leon 04/15/19 07:47PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/15/19 07:59PM
  Re: New cars are shitRe: Dirty30 Dillon Dirty30 Dillon 04/17/19 01:22PM
  Re: New cars are shitRe: Paola De Leon Paola De Leon 04/15/19 08:25PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/15/19 11:21PM
  Re: New cars are shitRe: Paola De Leon Paola De Leon 04/15/19 11:48PM
  Re: New cars are shitRe: Andrew Squiggman Andrew Squiggman 04/16/19 12:01AM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/15/19 08:32PM
  Re: Burned-out, incompetent ex-mechanics are shitRe: Paola De Leon Paola De Leon 04/15/19 09:01PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/16/19 01:03AM
  Re: New cars are shitRe: Paola De Leon Paola De Leon 04/16/19 10:33AM
  Re: New cars are shitRe: Stephen Keller Stephen Keller 04/16/19 01:11AM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/16/19 01:20AM
  Re: New cars are shitRe: Jimmy Cincinnati Jimmy Cincinnati 04/16/19 10:29AM
  Re: New cars are shitRe: Stephen Keller Stephen Keller 04/16/19 03:14PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/16/19 08:24PM
  Re: New cars are shitRe: Born to be WillD Born to be WillD 04/17/19 09:38AM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/16/19 11:52PM
  Re: New cars are shitRe: Stephen Keller Stephen Keller 04/17/19 04:03AM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/17/19 04:28PM
  Re: New cars are shitRe: Thomas TPRF Thomas TPRF 04/17/19 12:09PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/17/19 01:27PM
  Re: New cars are shitRe: Born to be WillD Born to be WillD 04/17/19 01:50PM
  Re: New cars are shitRe: Thomas TPRF Thomas TPRF 04/17/19 03:18PM
  Re: New cars are shitRe: Paola De Leon Paola De Leon 04/17/19 05:08PM
  Re: New cars are shitRe: Jimmy Cincinnati Jimmy Cincinnati 04/17/19 07:22AM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/17/19 10:31AM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/17/19 02:00PM
  Re: New cars are shitRe: Dirty30 Dillon Dirty30 Dillon 04/17/19 02:21PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/17/19 02:39PM
  Re: New cars are shitRe: Dirty30 Dillon Dirty30 Dillon 04/17/19 02:49PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/17/19 03:40PM
  Re: New cars are shitRe: Dirty30 Dillon Dirty30 Dillon 04/17/19 04:05PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/17/19 04:36PM
  Re: New cars are shitRe: Dirty30 Dillon Dirty30 Dillon 04/17/19 04:41PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/17/19 04:39PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/17/19 04:40PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/17/19 04:47PM
  Re: New cars are shitRe: Dirty30 Dillon Dirty30 Dillon 04/17/19 05:15PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/17/19 05:28PM
  Re: New cars are shitRe: Dirty30 Dillon Dirty30 Dillon 04/17/19 10:05PM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/18/19 08:33AM
  Re: New cars are shitRe: P8R . P8R . 04/17/19 10:06PM
  Re: New cars are shitRe: Dirty30 Dillon Dirty30 Dillon 04/17/19 10:07PM
  Re: New cars are shitRe: P8R . P8R . 04/17/19 10:09PM
  Re: New cars are shitRe: Dirty30 Dillon Dirty30 Dillon 04/18/19 09:06AM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/17/19 10:17PM
  Re: New cars are shitRe: Jimmy Cincinnati Jimmy Cincinnati 04/18/19 07:42AM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/18/19 11:25AM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/18/19 08:53AM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/18/19 09:09AM
  Re: New cars are shitRe: Dirty30 Dillon Dirty30 Dillon 04/18/19 10:09AM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/18/19 10:22AM
  Re: New cars are shitRe: Dirty30 Dillon Dirty30 Dillon 04/18/19 10:24AM
  Re: New cars are shitRe: Jimmy Cincinnati Jimmy Cincinnati 04/18/19 11:53AM
  Re: New cars are shitRe: kevin Smellaflange kevin Smellaflange 04/18/19 12:16PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/18/19 12:19PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/18/19 12:26PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/18/19 12:39PM
  Re: New cars are shitRe: kevin Smellaflange kevin Smellaflange 04/18/19 12:40PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/18/19 12:45PM
  Re: New cars are shitRe: Paola De Leon Paola De Leon 04/18/19 07:12PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/18/19 12:55PM
  Re: New cars are shitRe: kevin Smellaflange kevin Smellaflange 04/18/19 01:10PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/18/19 01:14PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/18/19 01:17PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/18/19 01:54PM
  Re: New cars are shitRe: Jimmy Cincinnati Jimmy Cincinnati 04/18/19 02:01PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/18/19 02:12PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/18/19 04:28PM
  Re: New cars are shitRe: kevin Smellaflange kevin Smellaflange 04/18/19 05:11PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/18/19 06:07PM
  Re: New cars are shitRe: Dirty30 Dillon Dirty30 Dillon 04/18/19 11:06PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/18/19 06:34PM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/18/19 06:39PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/18/19 06:58PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/18/19 07:52PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/18/19 08:47PM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/19/19 03:31AM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/18/19 09:22PM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/18/19 10:52PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/18/19 11:00PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/18/19 11:52PM
  Re: New cars are shitRe: Dirty30 Dillon Dirty30 Dillon 04/19/19 07:14AM
  Re: New cars are shitRe: Stephen Keller Stephen Keller 04/19/19 07:58PM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/19/19 09:03PM
  Re: New cars are shitRe: Stephen Keller Stephen Keller 04/19/19 09:11PM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/19/19 09:21PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/18/19 11:59PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/19/19 04:07AM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/19/19 07:44AM
  Re: New cars are shitRe: Jimmy Cincinnati Jimmy Cincinnati 04/19/19 08:05AM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/19/19 08:15AM
  Re: New cars are shitRe: Jimmy Cincinnati Jimmy Cincinnati 04/19/19 09:50AM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/19/19 10:51AM
  Re: New cars are shitRe: Jimmy Cincinnati Jimmy Cincinnati 04/19/19 11:34AM
  Re: New cars are shitRe: Paola De Leon Paola De Leon 04/19/19 11:56AM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/19/19 01:27PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/19/19 11:37AM
  Re: New cars are shitRe: Jimmy Cincinnati Jimmy Cincinnati 04/19/19 11:56AM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/19/19 01:24PM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/19/19 01:36PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/19/19 01:59PM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/19/19 07:12PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/19/19 02:03PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/19/19 02:14PM
  Re: New cars are shitRe: Jeff Parr Jeff Parr 04/20/19 04:18AM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/20/19 07:43AM
  Re: New cars are shitRe: kevin Smellaflange kevin Smellaflange 04/20/19 12:08PM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/20/19 12:31PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/20/19 02:30PM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/20/19 03:32PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/20/19 04:40PM
  Re: New cars are shitRe: P8R . P8R . 04/20/19 06:24PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/20/19 06:52PM
  Re: New cars are shitRe: kevin Smellaflange kevin Smellaflange 04/20/19 07:18PM
  Re: New cars are shitRe: P8R . P8R . 04/20/19 09:58PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/20/19 11:47PM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/21/19 11:58AM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/21/19 07:25PM
  Re: New cars are shitRe: Overpriced Parts Overpriced Parts 04/22/19 05:32PM
  Re: New cars are shitRe: Andrew Squiggman Andrew Squiggman 04/21/19 12:08AM
  Re: New cars are shitRe: Dirty30 Dillon Dirty30 Dillon 04/21/19 12:08PM
  Re: New cars are shitRe: Stephen Keller Stephen Keller 04/21/19 03:22PM
  Re: New cars are shitRe: A Zed A Zed 04/22/19 09:01AM
  Re: New cars are shitRe: Jimmy Cincinnati Jimmy Cincinnati 04/22/19 09:13AM
  Re: New cars are shitRe: A Zed A Zed 04/22/19 09:28AM
  Re: New cars are shitRe: kevin Smellaflange kevin Smellaflange 04/22/19 09:49AM
  Re: New cars are shitRe: A Zed A Zed 04/22/19 09:49AM
  Re: New cars are shitRe: Born to be WillD Born to be WillD 04/22/19 11:57AM
  Re: New cars are shitRe: Stephen Keller Stephen Keller 04/22/19 02:32PM
  Re: New cars are shitRe: Dirty30 Dillon Dirty30 Dillon 04/22/19 02:43PM
  Re: New cars are shitRe: Stephen Keller Stephen Keller 04/22/19 02:47PM
  Re: New cars are shitRe: Jimmy Cincinnati Jimmy Cincinnati 04/22/19 01:18PM
  Re: New cars are shitRe: kevin Smellaflange kevin Smellaflange 04/22/19 02:55PM
  Re: New cars are shitRe: Overpriced Parts Overpriced Parts 04/22/19 04:54PM
  Re: New cars are shitRe: Dirty30 Dillon Dirty30 Dillon 04/22/19 05:18PM
  Re: New cars are shitRe: kevin Smellaflange kevin Smellaflange 04/22/19 05:45PM
  Re: New cars are shitRe: Jimmy Cincinnati Jimmy Cincinnati 04/22/19 04:57PM
  Re: New cars are shitRe: Overpriced Parts Overpriced Parts 04/22/19 05:47PM
  Re: New cars are shitRe: kevin Smellaflange kevin Smellaflange 04/22/19 06:01PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/22/19 06:15PM
  Re: New cars are shitRe: A Zed A Zed 04/22/19 07:13PM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/22/19 07:44PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/22/19 08:31PM
  Re: New cars are shitRe: A Zed A Zed 04/22/19 11:06PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/22/19 11:50PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/22/19 08:32PM
  Re: New cars are shitRe: Born to be WillD Born to be WillD 04/23/19 11:29AM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/23/19 12:30PM
  Re: New cars are shitRe: Born to be WillD Born to be WillD 04/23/19 01:59PM
  Re: New cars are shitRe: Overpriced Parts Overpriced Parts 04/23/19 12:42PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/23/19 01:18PM
  Re: New cars are shitRe: kevin Smellaflange kevin Smellaflange 04/23/19 01:25PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/23/19 09:23PM
  Re: New cars are shitRe: Stephen Keller Stephen Keller 04/23/19 02:12PM
  Re: New cars are shitRe: Overpriced Parts Overpriced Parts 04/23/19 03:41PM
  Re: New cars are shitRe: Born to be WillD Born to be WillD 04/24/19 09:36AM
  Re: New cars are shitRe: Born to be WillD Born to be WillD 04/23/19 02:03PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/23/19 02:11PM
  Re: New cars are shitRe: Dirty30 Dillon Dirty30 Dillon 04/23/19 02:28PM
  Re: New cars are shitRe: kevin Smellaflange kevin Smellaflange 04/23/19 02:26PM
  Re: New cars are shitRe: Born to be WillD Born to be WillD 04/23/19 02:54PM
  Re: New cars are shitRe: Overpriced Parts Overpriced Parts 04/23/19 03:48PM
  Re: New cars are shitRe: Born to be WillD Born to be WillD 04/23/19 02:47PM
  Re: New cars are shitRe: Dirty30 Dillon Dirty30 Dillon 04/23/19 03:46PM
  Re: New cars are shitRe: Overpriced Parts Overpriced Parts 04/23/19 03:53PM
  Re: New cars are shitRe: Dirty30 Dillon Dirty30 Dillon 04/23/19 04:14PM
  Re: New cars are shitRe: kevin Smellaflange kevin Smellaflange 04/23/19 04:36PM
  Re: New cars are shitRe: Overpriced Parts Overpriced Parts 04/23/19 07:31PM
  Re: New cars are shitRe: Stephen Keller Stephen Keller 04/23/19 10:23PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/24/19 01:04AM
  Re: New cars are shitRe: A Zed A Zed 04/23/19 09:48PM
  Re: New cars are shitRe: kevin Smellaflange kevin Smellaflange 04/23/19 07:58PM
  Re: New cars are shitRe: Overpriced Parts Overpriced Parts 04/23/19 09:17PM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/23/19 10:51PM
  Re: New cars are shitRe: Stephen Keller Stephen Keller 04/24/19 01:10AM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/24/19 01:30AM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/24/19 01:18AM
  Re: New cars are shitRe: Stephen Keller Stephen Keller 04/24/19 02:58AM
  Re: New cars are shitRe: P8R . P8R . 04/24/19 09:54AM
  Re: New cars are shitRe: Born to be WillD Born to be WillD 04/24/19 04:13PM
  Re: New cars are shitRe: Overpriced Parts Overpriced Parts 04/24/19 04:39PM
  Re: New cars are shitRe: Born to be WillD Born to be WillD 04/25/19 10:11AM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/24/19 02:55AM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/25/19 01:07AM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/25/19 06:52AM
  Re: New cars are shitRe: Stephen Keller Stephen Keller 04/25/19 01:27PM
  Re: New cars are shitRe: Dirty30 Dillon Dirty30 Dillon 04/25/19 08:47AM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/25/19 11:52PM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/26/19 01:02AM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/26/19 01:44AM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/26/19 07:35AM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/25/19 10:13AM
  Re: New cars are shitRe: Born to be WillD Born to be WillD 04/25/19 10:36AM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/25/19 12:56PM
  Re: New cars are shitRe: Jimmy Cincinnati Jimmy Cincinnati 04/26/19 09:20AM
  Re: New cars are shitRe: kevin Smellaflange kevin Smellaflange 04/26/19 09:26AM
  Re: New cars are shitRe: Jimmy Cincinnati Jimmy Cincinnati 04/26/19 09:37AM
  Re: New cars are shitRe: Born to be WillD Born to be WillD 04/26/19 09:46AM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/26/19 09:40AM
  Re: New cars are shitRe: Jimmy Cincinnati Jimmy Cincinnati 04/26/19 11:18AM
  Re: New cars are shitRe: Born to be WillD Born to be WillD 04/26/19 11:50AM
  Re: New cars are shitRe: Stephen Keller Stephen Keller 04/26/19 12:01PM
  Re: New cars are shitRe: Jimmy Cincinnati Jimmy Cincinnati 04/26/19 11:54AM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/26/19 12:04PM
  Re: New cars are shitRe: kevin Smellaflange kevin Smellaflange 04/26/19 12:20PM
  Re: New cars are shitRe: A Zed A Zed 04/26/19 02:06PM
  Re: New cars are shitRe: Jimmy Cincinnati Jimmy Cincinnati 04/26/19 12:21PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/26/19 12:43PM
  Re: New cars are shitRe: Jimmy Cincinnati Jimmy Cincinnati 04/26/19 02:00PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/26/19 02:11PM
  Re: New cars are shitRe: Thomas TPRF Thomas TPRF 04/26/19 02:31PM
  Re: New cars are shitRe: A Zed A Zed 04/26/19 02:42PM
  Re: New cars are shitRe: kevin Smellaflange kevin Smellaflange 04/26/19 02:55PM
  Re: New cars are shitRe: Thomas TPRF Thomas TPRF 04/26/19 03:29PM
  Re: New cars are shitRe: Thomas TPRF Thomas TPRF 04/26/19 03:25PM
  Re: New cars are shitRe: A Zed A Zed 04/26/19 03:28PM
  Re: New cars are shitRe: Thomas TPRF Thomas TPRF 04/26/19 03:30PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/26/19 03:36PM
  Re: New cars are shitRe: Thomas TPRF Thomas TPRF 04/26/19 04:12PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/26/19 04:20PM
  Re: New cars are shitRe: Thomas TPRF Thomas TPRF 04/26/19 04:31PM
  Re: New cars are shitRe: A Zed A Zed 04/26/19 03:37PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/26/19 02:37PM
  Re: New cars are shitRe: Jimmy Cincinnati Jimmy Cincinnati 04/26/19 02:56PM
  Re: New cars are shitRe: Stephen Keller Stephen Keller 04/26/19 03:51PM
  Re: New cars are shitRe: Jimmy Cincinnati Jimmy Cincinnati 04/26/19 04:04PM
  Re: New cars are shitRe: A Zed A Zed 04/26/19 04:23PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/26/19 05:54PM
  Re: New cars are shitRe: Born to be WillD Born to be WillD 04/29/19 01:18PM
  Re: New cars are shitRe: Overpriced Parts Overpriced Parts 04/29/19 02:42PM
  Re: New cars are shitRe: kevin Smellaflange kevin Smellaflange 04/29/19 03:26PM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/29/19 06:28PM
  Re: New cars are shitRe: kevin Smellaflange kevin Smellaflange 04/29/19 06:55PM
  Re: New cars are shitRe: A Zed A Zed 04/26/19 06:19PM
  Re: New cars are shitRe: Overpriced Parts Overpriced Parts 04/26/19 06:37PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/26/19 06:47PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/26/19 07:06PM
  Re: New cars are shitRe: A Zed A Zed 04/26/19 08:09PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/26/19 09:23PM
  Re: New cars are shitRe: A Zed A Zed 04/26/19 10:00PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/26/19 10:48PM
  Re: New cars are shitRe: Thomas TPRF Thomas TPRF 04/27/19 12:34AM
  Re: New cars are shitRe: Dirty30 Dillon Dirty30 Dillon 04/29/19 02:08PM
  Re: New cars are shitRe: Born to be WillD Born to be WillD 04/29/19 01:36PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/27/19 01:08AM
  Re: New cars are shitRe: A Zed A Zed 04/27/19 02:22AM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/27/19 06:33AM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/27/19 06:39AM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/27/19 08:30AM
  Re: New cars are shitRe: A Zed A Zed 04/27/19 10:59AM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/27/19 11:31AM
  Re: New cars are shitRe: kevin Smellaflange kevin Smellaflange 04/27/19 12:25PM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/27/19 12:53PM
  Re: New cars are shitRe: Thomas TPRF Thomas TPRF 04/27/19 12:31PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/27/19 12:38PM
  Re: New cars are shitRe: Thomas TPRF Thomas TPRF 04/27/19 04:06PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 04/27/19 01:05PM
  Re: New cars are shitRe: kevin Smellaflange kevin Smellaflange 04/27/19 04:25PM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/28/19 03:00PM
  Re: New cars are shitRe: __̴ı̴̴̡̡̡ ̡͌l̡̡̡ ̡͌l̡*̡̡ ̴̡ı̴̴̡ ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡͡ ̲|̡̡̡ ̡ ̴̡ı̴̡̡ ̡͌l̡̡̡̡.__ __̴ı̴̴̡̡̡ ̡͌l̡̡̡ ̡͌l̡*̡̡ ̴̡ı̴̴̡ ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡͡ ̲|̡̡̡ ̡ ̴̡ı̴̡̡ ̡͌l̡̡̡̡.__ 04/28/19 08:45PM
  Re: New cars are shitRe: A Zed A Zed 04/28/19 10:05PM
  Re: New cars are shitRe: A Zed A Zed 04/29/19 06:59PM
  Re: New cars are shitRe: kevin Smellaflange kevin Smellaflange 04/29/19 07:02PM
  Re: New cars are shitRe: A Zed A Zed 04/29/19 07:03PM
  Re: New cars are shitRe: kevin Smellaflange kevin Smellaflange 04/29/19 07:06PM
  Re: New cars are shitRe: A Zed A Zed 04/29/19 07:07PM
  Re: New cars are shitRe: kevin Smellaflange kevin Smellaflange 04/29/19 07:10PM
  Re: New cars are shitRe: kevin Smellaflange kevin Smellaflange 04/30/19 03:53PM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/29/19 08:55PM
  Re: New cars are shitRe: kevin Smellaflange kevin Smellaflange 04/29/19 09:49PM
  Re: New cars are shitRe: kevin Smellaflange kevin Smellaflange 04/29/19 09:53PM
  Re: New cars are shitRe: kevin Smellaflange kevin Smellaflange 04/29/19 09:57PM
  Re: New cars are shitRe: kevin Smellaflange kevin Smellaflange 04/29/19 10:04PM
  Re: New cars are shitRe: kevin Smellaflange kevin Smellaflange 04/29/19 10:09PM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/30/19 05:39AM
  Re: New cars are shitRe: kevin Smellaflange kevin Smellaflange 04/30/19 08:24AM
  Re: New cars are shitRe: Dirty30 Dillon Dirty30 Dillon 04/30/19 10:45AM
  Re: New cars are shitRe: kevin smellaflange kevin smellaflange 04/30/19 11:39AM
  Re: New cars are shitRe: Dirty30 Dillon Dirty30 Dillon 04/30/19 11:46AM
  Re: New cars are shitRe: kevin smellaflange kevin smellaflange 04/30/19 12:05PM
  Re: New cars are shitRe: kevin smellaflange kevin smellaflange 04/30/19 05:23PM
  Re: New cars are shitRe: Thomas TPRF Thomas TPRF 04/30/19 08:30PM
  Re: New cars are shitRe: Don Ohio Don Ohio 04/30/19 09:52PM
  Re: New cars are shitRe: kevin smellaflange kevin smellaflange 05/01/19 11:39AM
  Re: New cars are shitRe: kevin smellaflange kevin smellaflange 05/01/19 03:35PM
  Re: New cars are shitRe: kevin smellaflange kevin smellaflange 05/02/19 09:11AM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 05/10/19 01:13PM
  Re: New cars are shitRe: Stephen Keller Stephen Keller 05/10/19 06:12PM
  Re: New cars are shitRe: Born to be WillD Born to be WillD 05/13/19 03:16PM
  Re: New cars are shitRe: Thomas TPRF Thomas TPRF 05/13/19 06:00PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 05/10/19 05:53PM
  Re: New cars are shitRe: Thomas TPRF Thomas TPRF 05/10/19 06:52PM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 05/11/19 10:31AM
  Re: New cars are shitRe: Thomas TPRF Thomas TPRF 05/11/19 04:20PM
  Re: New cars are shitRe: Stephen Keller Stephen Keller 05/11/19 07:33PM
  Re: New cars are shitRe: Thomas TPRF Thomas TPRF 05/11/19 08:33PM
  Re: New cars are shitRe: Stephen Keller Stephen Keller 05/11/19 09:06PM
  Re: New cars are shitRe: Thomas TPRF Thomas TPRF 05/12/19 03:03PM
  Re: New cars are shitRe: Stephen Keller Stephen Keller 05/12/19 06:04PM
  Re: New cars are shitRe: Don Ohio Don Ohio 05/11/19 11:25PM
  Re: New cars are shitRe: Stephen Keller Stephen Keller 05/12/19 06:03PM
  Re: New cars are shitRe: Piston Port Piston Port 05/13/19 10:02AM
  Re: New cars are shitRe: Don Ohio Don Ohio 05/14/19 01:03AM
  Re: New cars are shitRe: Thomas TPRF Thomas TPRF 05/14/19 09:25AM
  Re: New cars are shitRe: Don Ohio Don Ohio 05/14/19 10:43AM
  Re: New cars are shitRe: Don Ohio Don Ohio 05/14/19 09:26PM
  Re: New cars are shitRe: Thomas TPRF Thomas TPRF 05/14/19 10:42PM
  Re: New cars are shitRe: Don Ohio Don Ohio 05/14/19 11:40PM
  Re: New cars are shitRe: jayson sumpter jayson sumpter 05/15/19 08:52AM
  Re: New cars are shitRe: jayson sumpter jayson sumpter 05/15/19 08:59AM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 05/14/19 11:21PM
  Re: New cars are shitRe: Born to be WillD Born to be WillD 05/15/19 10:03AM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 05/15/19 01:58PM
  Re: New cars are shitRe: Stephen Keller Stephen Keller 05/15/19 02:24PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 05/15/19 03:41PM
  Re: New cars are shitRe: Don Ohio Don Ohio 05/15/19 03:57PM
  Re: New cars are shitRe: ERIC from Idaho! ERIC from Idaho! 05/15/19 04:18PM
  Re: New cars are shitRe: Jose Leon Jose Leon 05/17/19 02:33PM
  Re: New cars are shitRe: Thomas TPRF Thomas TPRF 05/17/19 05:08PM
  Re: New cars are shitRe: Stephen Keller Stephen Keller 05/17/19 07:37PM
  Re: New cars are shitRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 05/24/19 02:25PM
  Re: New cars are shitRe: Thomas TPRF Thomas TPRF 05/24/19 06:54PM
  Re: New cars are shitRe: Don Ohio Don Ohio 05/15/19 06:51PM
  Re: New cars are shitRe: Angry Hipster Angry Hipster 05/15/19 09:22PM
