Re: 94 Blazer Catalytic Converter
Bad Cadillac™ /
Oh I listened to your first post for sure. I've removed cats before and the vehicle is more peppy and you can also get a little more exhaust smell. In ODB cars yes, no check engine because the O2 is before the cat but I also did not know if yours was OBD or OBD2. I was just asking you questions because you did not imply it is definately a clogged cat because the cat insides will not burn off like a moped exhaust and I did not want you to just start cutting parts off and such. So I did not know who was telling you it was a clogged cat.
I read you said the check engine was flickering on and were not worried about that. In my opinion, you should fix that as well so the engine performs it's best. Cover the light up and as more issues come up that would cause the light to come on, you will never know what the real issue is. Again, just my opinion. I once checked codes for a lady that had 7 different and she said the check engine light had been on for years!
It will continue to clog until it shuts the engine down or starts a fire.
Cut it off, straight pipe it and you are done. (edited)
  94 Blazer Catalytic ConverterTopic by: ~ DeeZy ~ DeeZy 04/18/17 10:33AM
  Re: 94 Blazer Catalytic ConverterRe: Probably Fred Probably Fred 04/18/17 11:00AM
  Re: 94 Blazer Catalytic ConverterRe: Bad Cadillac™ Bad Cadillac™ 04/18/17 11:08AM
  Re: 94 Blazer Catalytic ConverterRe: Probably Fred Probably Fred 04/18/17 11:45AM
  Re: 94 Blazer Catalytic ConverterRe: Bad Cadillac™ Bad Cadillac™ 04/18/17 11:51AM
  Re: 94 Blazer Catalytic ConverterRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/18/17 01:30PM
  Re: 94 Blazer Catalytic ConverterRe: ~ DeeZy ~ DeeZy 04/18/17 01:32PM
  Re: 94 Blazer Catalytic ConverterRe: Don Wayne (Ofmc) Don Wayne (Ofmc) 04/18/17 11:57AM
  Re: 94 Blazer Catalytic ConverterRe: Bad Cadillac™ Bad Cadillac™ 04/18/17 12:02PM
  Re: 94 Blazer Catalytic ConverterRe: cheetahchrome . cheetahchrome . 04/18/17 12:21PM
  Re: 94 Blazer Catalytic ConverterRe: ~ DeeZy ~ DeeZy 04/18/17 01:31PM
  Re: 94 Blazer Catalytic ConverterRe: Stephen Keller Stephen Keller 04/18/17 01:35PM
  Re: 94 Blazer Catalytic ConverterRe: Don Wayne (Ofmc) Don Wayne (Ofmc) 04/18/17 02:08PM
  Re: 94 Blazer Catalytic ConverterRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/18/17 02:48PM
  Re: 94 Blazer Catalytic ConverterRe: Bad Cadillac™ Bad Cadillac™ 04/18/17 02:42PM
  Re: 94 Blazer Catalytic ConverterRe: ~ DeeZy ~ DeeZy 04/19/17 11:29AM
  Re: 94 Blazer Catalytic ConverterRe: Probably Fred Probably Fred 04/19/17 12:07PM
  Re: 94 Blazer Catalytic ConverterRe: - Dacruzer - - Dacruzer - 04/19/17 01:00PM
