Re: 94 Blazer Catalytic Converter
94 V6, so it's a 4.3L S-10 blazer. It could be a central fuel injected motor or a multi-port fuel injection(10th digit Z in the vin)
Neither had an O2 sensor after the cat, so the computer does not monitor cat efficiency and doing away with the cat will not put the light on.
A clogged cat will screw with it more than no cat would, hence the poor fuel economy. I'd drop the pipe down behind the cat and poke a bar in there and break up the internals and gut it. Start it with the pipe off then and rev it to blow out all remaining pieces so it doesn't end up down stream and become a clogged muffler. Just don't tell the feds that you performed surgery on your converter. ;)
Disclaimer:
The above proceedure is for test purposes only. All emissions related equipment should be present on your vehicle to comply with federal regulations.
  94 Blazer Catalytic ConverterTopic by: ~ DeeZy ~ DeeZy 04/18/17 10:33AM
  Re: 94 Blazer Catalytic ConverterRe: Probably Fred Probably Fred 04/18/17 11:00AM
  Re: 94 Blazer Catalytic ConverterRe: Bad Cadillac™ Bad Cadillac™ 04/18/17 11:08AM
  Re: 94 Blazer Catalytic ConverterRe: Probably Fred Probably Fred 04/18/17 11:45AM
  Re: 94 Blazer Catalytic ConverterRe: Bad Cadillac™ Bad Cadillac™ 04/18/17 11:51AM
  Re: 94 Blazer Catalytic ConverterRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/18/17 01:30PM
  Re: 94 Blazer Catalytic ConverterRe: ~ DeeZy ~ DeeZy 04/18/17 01:32PM
  Re: 94 Blazer Catalytic ConverterRe: Don Wayne (Ofmc) Don Wayne (Ofmc) 04/18/17 11:57AM
  Re: 94 Blazer Catalytic ConverterRe: Bad Cadillac™ Bad Cadillac™ 04/18/17 12:02PM
  Re: 94 Blazer Catalytic ConverterRe: cheetahchrome . cheetahchrome . 04/18/17 12:21PM
  Re: 94 Blazer Catalytic ConverterRe: ~ DeeZy ~ DeeZy 04/18/17 01:31PM
  Re: 94 Blazer Catalytic ConverterRe: Stephen Keller Stephen Keller 04/18/17 01:35PM
  Re: 94 Blazer Catalytic ConverterRe: Don Wayne (Ofmc) Don Wayne (Ofmc) 04/18/17 02:08PM
  Re: 94 Blazer Catalytic ConverterRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/18/17 02:48PM
  Re: 94 Blazer Catalytic ConverterRe: Bad Cadillac™ Bad Cadillac™ 04/18/17 02:42PM
  Re: 94 Blazer Catalytic ConverterRe: ~ DeeZy ~ DeeZy 04/19/17 11:29AM
  Re: 94 Blazer Catalytic ConverterRe: Probably Fred Probably Fred 04/19/17 12:07PM
  Re: 94 Blazer Catalytic ConverterRe: - Dacruzer - - Dacruzer - 04/19/17 01:00PM
