Re: 94 Blazer Catalytic Converter
Bad Cadillac™ /
Ken Roff Wrote:
> Bad Cadillac™ Wrote:
> > Are you sure it's not your oxygen sensors?
> > You should really pull the codes and see what
> the
> > heck is going on with the engine before
> replacing
> > any parts.
> He didn't say any check engine lights were on,
> Sensor is in front of convertor anyway.
> Pretty sure with that old age (23 years)
> converters blocked but ya it all needs a tune up,
> Throttlebody cleaned, new plugs, wires cap, rotor,
> run diagnostics heck yeah specially if it hasn't
> been done for a while.
> Give it the treatment
He did say the check engine light was on: "I know it'll probably make the engine light come on, but it already does quite often. Not worried about that."
The O2 sensor may also be 23 years old. Bad O2 typically kill MPG too.
Pull the codes before cutting off the converter to be sure that is def your issue.
  94 Blazer Catalytic ConverterTopic by: ~ DeeZy ~ DeeZy 04/18/17 10:33AM
  Re: 94 Blazer Catalytic ConverterRe: Probably Fred Probably Fred 04/18/17 11:00AM
  Re: 94 Blazer Catalytic ConverterRe: Bad Cadillac™ Bad Cadillac™ 04/18/17 11:08AM
  Re: 94 Blazer Catalytic ConverterRe: Probably Fred Probably Fred 04/18/17 11:45AM
  Re: 94 Blazer Catalytic ConverterRe: Bad Cadillac™ Bad Cadillac™ 04/18/17 11:51AM
  Re: 94 Blazer Catalytic ConverterRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/18/17 01:30PM
  Re: 94 Blazer Catalytic ConverterRe: ~ DeeZy ~ DeeZy 04/18/17 01:32PM
  Re: 94 Blazer Catalytic ConverterRe: Don Wayne (Ofmc) Don Wayne (Ofmc) 04/18/17 11:57AM
  Re: 94 Blazer Catalytic ConverterRe: Bad Cadillac™ Bad Cadillac™ 04/18/17 12:02PM
  Re: 94 Blazer Catalytic ConverterRe: cheetahchrome . cheetahchrome . 04/18/17 12:21PM
  Re: 94 Blazer Catalytic ConverterRe: ~ DeeZy ~ DeeZy 04/18/17 01:31PM
  Re: 94 Blazer Catalytic ConverterRe: Stephen Keller Stephen Keller 04/18/17 01:35PM
  Re: 94 Blazer Catalytic ConverterRe: Don Wayne (Ofmc) Don Wayne (Ofmc) 04/18/17 02:08PM
  Re: 94 Blazer Catalytic ConverterRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/18/17 02:48PM
  Re: 94 Blazer Catalytic ConverterRe: Bad Cadillac™ Bad Cadillac™ 04/18/17 02:42PM
  Re: 94 Blazer Catalytic ConverterRe: ~ DeeZy ~ DeeZy 04/19/17 11:29AM
  Re: 94 Blazer Catalytic ConverterRe: Probably Fred Probably Fred 04/19/17 12:07PM
  Re: 94 Blazer Catalytic ConverterRe: - Dacruzer - - Dacruzer - 04/19/17 01:00PM
